VLAN Configuration for Internal and Guest Wireless
Dec 16th, 2013
We are using the following hardware…
SG300-52MP switch -- latest firmware
ASA 5512-X firewall -- 9.1
Aironet AP1131AG WAP
We have the following networks…
10.252.4.0/24 = Internal = ASA-01 interface = VLAN1
10.252.6.0/24 = Guest = ASA-02 interface = VLAN6
10.252.6.0/24 = VOIP = ASA-03 interface = VLAN3
The Aironet supports two SSIDs, Secure (RADIUS) and Guest (WPA2), which are supposed to provide access to the appropriate interface on the ASA.
Relevant parts of the WAP configuration are…
dot11 ssid GUEST
   vlan 6
dot11 ssid SECURE
   vlan 1
interface Dot11Radio0
no ip address
ssid GUEST
ssid SECURE
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
interface Dot11Radio0.6
encapsulation dot1Q 6
no ip route-cache
bridge-group 255
interface Dot11Radio1
no ip address
no ip route-cache
ssid GUEST
ssid SECURE
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface Dot11Radio1.6
no ip route-cache
bridge-group 255
interface FastEthernet0
no ip address
no ip route-cache
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.6
no ip route-cache
bridge-group 255
interface BVI1
ip address 10.252.4.4 255.255.255.0
no ip route-cache
ip default-gateway 10.252.4.1
We can manage the WAP through it’s Internal IP address (10.252.4.4).
And the “Guest” wireless network is working -- connecting to that SSID provides the client with the correct IP addressing (10.242.6.X from VLAN6/ASA-02).  [Note:  the VOIP DHCP and network access also works correctly.]
The “Secure” wireless network is not working however -- the client never receives an Internal DHCP address from ASA-01, and even if you hard-code the client’s IP, no IP4 traffic ever passes.
[Note:  connecting a device to a SG300 port with the “Default” configuration provides the client with an Internal DHCP configuration, and it works as intended.]
While this may be a problem with the WAP configuration, I would like to confirm that it is not an issue with the switch not passing traffic correctly.
I have a feeling that I have configured the VLANs on the ports incorrectly.
Relevant parts of the SG300 configuration are...
v1.3.0.62 / R750_NIK_1_3_647_260
vlan database
vlan 3,6
ip dhcp snooping
ip dhcp relay address 10.252.4.1
ip dhcp relay enable
bonjour interface range vlan 1
interface vlan 1
ip address 10.252.4.2 255.255.255.0
no ip address dhcp
interface vlan 3
name VOIP
interface vlan 6
name Guest
interface gigabitethernet45 -- Access mode, Untagged VLAN6
description ASA-Guest
ip dhcp snooping trust
switchport mode access
switchport access vlan 6
interface gigabitethernet46 -- Access mode, Untagged VLAN3
description ASA-VOIP
switchport access vlan 3
interface gigabitethernet47 -- Trunk mode, Untagged VLAN1 and Tagged VLAN6
description WAP1
switchport trunk allowed vlan add 6
interface gigabitethernet48 -- Trunk mode
description ASA-Internal
Can someone who understands this switch better than I do please confirm the VLAN configuration?  THANK YOU!
