Warning message
Display Skills next to Agent in Supervisor Console
Dec 17th, 2013
Hi All,
Is there any way to display skills next to the Agent in supervisor Console? I have a customer that Agents Skills get changed from time to time, and supervisor wants to see that.
HM
Gergely Szabo Tue, 12/17/2013 - 23:33
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
is it UCCX or UCCE? CAD or CTI OS?
G.
ANGEL FERNANDEZ... Wed, 12/18/2013 - 05:06
Hi, I have the same cuestion, my customer has installed UCCXExpress 9.02.
Thank you.
Jonathan Schulenberg Wed, 12/18/2013 - 06:06
  • Cisco Designated VIP,
    2017 IP Telephony
The closest you can get in CSD is to click on a CSQ in the left column tree-view. It will show you all of the agents currently skilled in it. You cannot see a list of the CSQs a specific agent is in though, unfortunately. This is available within /appadmin on the Resource Configuration page by clicking the Open Printable Report link in the upper-right.
Please remember to rate helpful responses and identify helpful or correct answers.
ANGEL FERNANDEZ... Wed, 12/18/2013 - 06:38
Hi Jonathan, my system is UCCXExpress. I´m using CAD. I have tried look for these option and I  don´t find it, Could you tell me where configure these options?
Thanks you.
Jonathan Schulenberg Wed, 12/18/2013 - 06:40
    2017 IP Telephony
None of this information is available in CAD.
CSD is Cisco Supervisor Desktop, a separate Windows application you must have permissions and team role assignment to run. The http:///appadmin is the administrative UI. The menu for this is Subsystems > RmCm > Resources.
