RV320 slow NAT transfer rate
Dec 17th, 2013
Yesterday I have received by RV320 router. I have set it up with dual WAN:
WAN 1 - 1 Gbps - PPPoE
WAN 2 - 100 Mbps - Dynamic IP
after fixing the problem found initially that WAN1 get connected/Inactive, I found out that maximum transfer rate that I can achieve was around 250 Mbps at download and about 100 Mbps upload. The advertise value for NAT transfer rate for this device is 900 Mbps...
If I conenct directly the Cat 6 cable (used to conenct WAN1) to my PC I can get over 900 Mbps.
Is there any settings that limits this transfer rate? I'm not using any VPN tunneling or any other feature of the router as of right now and I have the latest public availbe firmware.
Gabi
Gabriel Ciuloaica Sun, 12/22/2013 - 03:50
Is  there anybody from Cisco that could help with this problem ? I've already spent days trying to figure out how to make it work with more than 200 Mbps...
mpyhala Mon, 12/23/2013 - 10:37
  • Gold, 750 points or more
Hi Gabriel,
Have you tried to disable Stateful Packet Inspection (SPI) under Firewall-> General? That may increase the performance.
- Marty
Gabriel Ciuloaica Mon, 12/23/2013 - 21:15
Hi Marty,
I have tried that, even disabled totally the firewall, but there was not much of improvements. Still the download remains about 260 Mbps...
Gabi
Gabriel Ciuloaica Fri, 12/05/2014 - 06:47
I was hopping that a new firmware upgrade will solve this issue, but with latest firmware I'm still not able go over 230 Mbps at download. On direct connection is going up to 900 Mbps.
So, Cisco guys, are you trying to fix this product or not?
clezau_ms Sat, 12/20/2014 - 03:51
I have this problem too in my home environment. I would like to open a support ticket and get this problem fixed.
Can somebody from support contact us to speed up the resolution?
We can provide net traces etc.
Related Content
