Warning message
site to site VPN peer ip address for failover
Karsten Iwen Wed, 12/18/2013 - 02:46
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Firewalling, VPN
You are probably not talking about an ASA-FO-system? There you don't need to configure two peers as the ip address will move to the secondary ASA when the primary fails.
If the two peers are individual boxes, then you can specify two peers in the "set peer" statement of your crypto map. If you use Pre-Shared-Keys, then you also have to configure a second tunnel-group for the backup-peer.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
