Cisco ASA5510 Firewall
Answered Question
Dec 18th, 2013
please  help  me  to  resolve  my  Issue  in the Cisco ASA 5510 firewall.  From  outside   port 3389  is  blocked  but   sitll  accessable  from   LAN IP  natted   with  the private  IP Address. Enclosed the  ASA config file.
Saroj Pradhan
Correct Answer by Julio Carvajal about 3 years 7 months ago
Hello Saroj,
So to move forward:
You can RDP locally to a server but you cannot from the internet.
What's the NAT you have configured for the server?
Also to get closer to the solution do
packet-tracer input outside tcp 4.2.2.2 1025 x.x.x.x 3389 (Where x.x.x.x is the outside public IP address of the Server)
Provide the entire output
Looking for some Networking Assistance?
Contact me directly at [email protected]
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
Overall Rating: 5 (2 ratings)
saroj pradhan Sat, 01/04/2014 - 18:26
The  Server  interface  has   Private  IP Address  and  for   access the server  from  Internet Natted   with  a  Public    IP Address.  Please  help   I want  to  blocked   the  RDP Port  access from Internet.
Marius Gunnerud Fri, 01/03/2014 - 05:06
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Firewalling
You config shows you have permited RDP from the outside
access-list outside_access_in extended permit tcp any any eq 3389
I am not sure what you mean by "still accessable from LAN IP natted with the prive IP address".  Could you please clarify this.
Please remember to rate and select a correct answer
Correct Answer
Julio Carvajal Fri, 01/03/2014 - 12:20
  • Purple, 4500 points or more
Hello Saroj,
So to move forward:
Cheers,
saroj pradhan Sat, 01/04/2014 - 18:24
plesae find the details.
The  server  private  ip  is  172.16.48.83   and   natted  with  public  ip  address  122.168.191.82.
Please find the report.
Netlink-OS-ASA# packet-tracer input outside tcp 4.2.2.2 1025 122.168.191.82 33$
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
static (inside,outside) Timesheet_Outside_Public Timesheet_Inside_Local netmask 255.255.255.255
  match ip inside host Timesheet_Inside_Local outside any
    static translation to Timesheet_Outside_Public
    translate_hits = 35877, untranslate_hits = 2503399
NAT divert to egress interface inside
Untranslate Timesheet_Outside_Public/0 to Timesheet_Inside_Local/0 using netmask 255.255.255.255
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group outside_access_in in interface outside
access-list outside_access_in extended permit ip any any
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 6
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group inside_access_out out interface inside
access-list inside_access_out extended permit ip any any
Phase: 7
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
    translate_hits = 35877, untranslate_hits = 2503421
Phase: 8
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
    translate_hits = 35877, untranslate_hits = 2503430
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 277395699, packet dispatched to next module
Phase: 11
Type: ROUTE-LOOKUP
Subtype: output and adjacency
Result: ALLOW
Config:
found next-hop VPN_AccesssL3 using egress ifc inside
adjacency Active
next-hop mac address 001a.a224.73c2 hits 2236
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
Correct Answer
Julio Carvajal Sat, 01/04/2014 - 20:04
Marius Gunnerud Sun, 01/05/2014 - 03:41
    2017 Firewalling
For the ASA to block/filter all traffic headed for 3389 then all traffic must pass through the ASA.  If it is a windows machine you could use the windows firewall to permit/deny RDP traffic.  If it is not a windows machine you could install a software firewall on it and use that to regulate traffic.
