Wi-Fi EAP + FAST login and password in AD (without certificates)
Dec 18th, 2013
  • Почетные Знаки Сообщества,
    Новичок, Январь 2014
Hello!
Who can tell the "normal" setting Wi-Fi EAP + FAST login and password in Active Directory (without certificates) with td Cisco + RADIUS-server (microsoft windows r2)???
Egor Khomenko Wed, 12/18/2013 - 16:05
+win7,8; android,apple
Stephen Rodriguez Wed, 12/18/2013 - 19:09
  • Purple, 4500 points or more
are you looking to do EAP-FAST?  If you are, then you can't do EAP-FAST with NPS/IAS, only Cisco ACS/ISE support FAST.
If you are going to use NPS/IAS then you can use PEAP, but that still requires a server side certificate, but it can be a self genearted one.
NPS Self SIgned Certificate
http://blog.samkendall.net/2011/10/13/creating-a-self-signed-certificate-on-windows-server-20082008-r2-without-iis/
NPS PEAP configuration
http://www.cisco.com/en/US/products/ps10315/products_configuration_example09186a0080bfb19a.shtml#anc11
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Egor Khomenko Wed, 12/18/2013 - 20:29
Whether you can then use other EAP without a certificate using the username and password???
Stephen Rodriguez Wed, 12/18/2013 - 20:48
PEAP would be the choice for username/password for NPS/IAS.  and it does require a server certificate.
HTH,
Steve
Egor Khomenko Wed, 12/18/2013 - 21:15
Is it possible to install certificates on ustraystva android and iPhone?
Trending Topics - Security & Network
