12-19-2013 08:31 AM - edited 03-19-2019 07:40 AM
I am running CUCM 9.1.1 we currently import our end users via LDAP. However we have a couple of local users that were created for other purposes. However when running a search on the corporate directory these local users appear. How can we hide them from appearing in the search? Turning them into application users is not an option, they need to be end users, and they were not imported via LDAP, they were created in CUCM.
12-19-2013 08:49 AM
Use LDAP filter. One example is to only import users with telephoneNumber or ipPhone (depending on which one you use). There are plenty examples of LDAP filters on this forum.
HTH,
Chris
12-19-2013 09:03 AM
I currently use the ipphone field for LDAP sync. However, I don't need to hide the users that are being imported from my active directory. I need to hide the users that were created directly in CUCM (they are not LDAP synced users)
12-19-2013 09:14 AM
I don't think you can hide them, so what purpose did you build them for? Usually any service accounts would only be built as application users.
HTH,
Chris
12-19-2013 09:30 AM
One account is used as a wallboard in our contact center. we tried creating it as an app user already but it wouldn't work the way we needed it to.
12-19-2013 09:38 AM
There is no way to hide those to my understanding.
Chris
