Warning message
No Answer Announcement
Answered Question
Dec 20th, 2013
Dear All,
I use CUCM 8.6 and I want to announce wav file  when phone not answerd. Is there any way configure it with out using Unity?
Emre
Correct Answer by Jonathan Schulenberg about 3 years 8 months ago
CUCM usually doesn't play media. There are some exceptions around the Annunciator service but it's not configurable and doesn't have CFNA in it's repertoire. The only options I can think of OTHER than Unity are:
  1. Contact Center Express / IP IVR
  2. A TCL script on the ingress PSTN gateway
Please remember to rate helpful responses and identify helpful or correct answers.
Correct Answer by Hermanus Janse ... about 3 years 8 months ago
I think the easiest is yes, you have a Call Forward No Answer CFNA pointing to a pilot number on Unity Connection.
In Unity connection you create a call handler that will accept the call on that pilot number and play a recording or something you have created.
Hope it helps or points you in the correct frame of mind or direction.
Overall Rating: 5 (2 ratings)
Correct Answer
Hermanus Janse ... Fri, 12/20/2013 - 02:00
  • Silver, 250 points or more
Correct Answer
Jonathan Schulenberg Sat, 12/21/2013 - 20:13
  • Cisco Designated VIP,
    2017 IP Telephony
