Warning message
RV Support VLAN Tagging on WAN Port?
Answered Question
Dec 20th, 2013
I'd like to know if RV Series Router can support VLAN tagging on the WAN port itself? I need this cause my ISP using such method to connect to end user modem/router.
Thank you.
Danny
Correct Answer by Zhaoqiang Wang about 3 years 7 months ago
please check RV315W.
Overall Rating: 5 (1 ratings)
Danny Cheng Chee Wah Fri, 12/20/2013 - 18:19
Hmm, it seems so... Saw SRP500 Series can support, but it's EOS/EOL now... Any replacement for that?
Danny
grantsmitton Mon, 07/21/2014 - 16:52
Anything available other than this RV315W?  That model is only 10/100 on the LAN.  VLAN on the WAN is fairly standard for fibre installs and should be a feature across all SMB routers.
