Firmware download for 3602i from 7500 WLC taking too long
Dec 20th, 2013
Hi friends,
Anyone encountered this scenario whereby when new APs bootup with the recovery software, and it starts to download firmware from a 7500 WLC, it takes too darn long. Sometimes upto 7 hours!
I have done for many sites and they are usually fast, around 1 hour max.
What can be the issue? Furthermore certain sites only start with a number of downloads and the rest of the AP waits for the others to finish. This is driving me mad. No issue with latency or anything.
WLC version: 7.5.102.0
AP recovery version: 7.3.1.53
This is the error I keep seeing in the logs:
*osapiReaper: Dec 20 22:56:52.915: #OSAPI-0-RAD_SW_UPGRADE: osapi_task.c:5190 System has been upgrading Radio SW for more than 30 minutes.
*spamApTask1: Dec 20 22:55:03.135: #DTLS-3-HANDSHAKE_FAILURE: openssl_dtls.c:698 Failed to complete DTLS handshake with peer 10.1.11.12
Overall Rating: 3 (1 ratings)
Stephen Rodriguez Fri, 12/20/2013 - 08:04
  • Purple, 4500 points or more
How many AP are you trying to upgrade at a site?
Have you looked at configuring a master AP?
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/consolidated/b_cg74_CONSOLIDATED_chapter_010010001.html
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Jagan1976 Fri, 12/20/2013 - 08:39
Only 5 3602i units. It downloads only 4 at one time. It has been running for 7 hours now.
On another site I am installing 8 3602i and only 3 can download at one time. Takes 6 hours minimum.
Looked at the Flexconnect AP upgrade with a "master" AP. However these are brand new APs out of the box and have not been added to the Flexconnect group.
(using option 43 via dhcp server for the AP to discover the WLC)
Rasika Nayanajith Fri, 12/20/2013 - 10:34
  • Cisco Designated VIP,
    2017 Wireless
It is good idea to stage them first (bring them to your location & pre-configure HA, FlexGroup, etc) prior to send it to remote branches.
What is the bandwidth you got to these sites, it should not take that long at all. If you could console onto one of the 3600 at remote brach it will tells us whats going on...
Rasika
***** Pls rate all useful responses ****
Related Content
