Warning message
AddRoute failed to add a route with metric of 0: code 160
Dec 20th, 2013
Problem: I am trying to connect to a external VPN with my smart card, they have other people connecting to this same VPN. I am able to authenticate with the VPN but after exactly 6 seconds I am disconnected with the error prompt below.  This happens every time.
Operating System: Windows 7 64 bit
VPN Client: 5.0.0.7.0440
Authentication: Smart Card
Transparent Tunneling Enabled.
Solutions Tried:
Multiple clients.
Hook directly to cable model.
Different ISP.
Different system.
DNE Update Tool.
Compatibility Mode.
Manually add route.
Different smart card reader.
Disconnect Prompt:
http://imgur.com/OaZ86B8
Reason 443: The Smart Card associated to the current certificate was removed.
Log output:
1      14:35:22.331  12/20/13  Sev=Warning/2          CVPND/0xE3400013
Destination          192.168.2.255
Netmask          255.255.255.255
Gateway          192.168.200.1
Interface          192.168.200.10
2      14:35:22.331  12/20/13  Sev=Warning/2          CM/0xA3100024
Unable to add route. Network: c0a802ff, Netmask: ffffffff, Interface: c0a8c80a, Gateway: c0a8c801.
3      14:35:28.150  12/20/13  Sev=Warning/2          CVPND/0xA3400015
Error with call to IpHlpApi.DLL: CheckUpVASettings: Found IPADDR entry addr=192.168.200.10, error 0
4      14:35:29.164  12/20/13  Sev=Warning/2          CVPND/0xA3400015
Error with call to IpHlpApi.DLL: CleanUpVASettings: Was able to delete all VA settings after all, error 0
5      14:35:29.866  12/20/13  Sev=Warning/2          IKE/0xA3000067
Received an IPC message during invalid state (IKE_MAIN:512)
Any help would be greatly appreciated.
abrhamlsmith Wed, 01/08/2014 - 18:10
Bump. Really need help with this guys.
Another solution I tried was setting up a windows xp virtual pc and still got the same error.
