Warning message
Load Balancing b/w two cisco router
Dec 23rd, 2013
Hello Friends,
Please advise me,We are using two Cisco Routers with F5 Load balancer,
Router A (Cisco 2811) has one ISP configured
Router B (Cisco 3825) has the other ISP configured
ISP on Router A has 5 Mbps Bandwidth
ISP on Router B has 10 Mbps Bandwidth
My Doubt is if the load balancer is down,how to utilize the ISP (or) How to divert the connection ?
Here i have attached my N/w diagram for ur reference..........
Can someone solve my question.............please
Thank you.
sathvik k v Fri, 12/27/2013 - 02:10
Whats the routing protocol used??
Sathvik K V
sathvik k v Mon, 12/30/2013 - 03:44
Hi Mohamed,
With default routing in use you can just configure one default route on each router   But it would only do load sharing not load balancing.
PFR(performance routing) is a better solution but have never tried with two diffferent router series. Also need to validate if the router series you are using supports PFR.
Sathvik K V
Related Content
