Warning message
Etherchannel 3925 and 3850
Dec 24th, 2013
I would like to create an etherchannel between a 3925 router and a 3850 switch.
I am using two of the internal ports on the router, as I can not create the etherchannel on the switch card I have
I would like a layer 3 interface between the two devices
Current configuration : 93 bytes
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
channel-group 1
end
#sh run int g 0/2
Building configuration...
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
channel-group 1
end
#show run int port-channel 1
Current configuration : 91 bytes
interface Port-channel1
ip address 192.168.1.1 255.255.255.252
hold-queue 0 in
end
sh etherchannel summary
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        R - Layer3      S - Layer2
        U - in use
Group Port-channel  Ports
I see nothing on the router???
On the switch side I can see the portchannel as up but I can not ping either end of the portchannel - pinging 192.168.1.1 from the switch fails and .2 from the router
Group  Port-channel  Protocol    Ports
1      Po1(RU)          -        Gi1/0/4(P)  Gi2/0/2(P)
2      Po2(RU)          -        Gi1/0/2(P)  Gi2/0/4(P)
3      Po3(SD)          -        Gi1/0/3(D)  Gi2/0/1(D)
4      Po4(RU)          -        Gi1/0/1(P)  Gi2/0/3(P)
switch interfaces as follows
interface GigabitEthernet1/0/1
  no switchport
no ip address
channel-group 4 mode on
end
devils_advocate Tue, 12/24/2013 - 03:17
  • Gold, 750 points or more
  • Community Spotlight Award,
    Small Business, November 2015
Can you do a show run on Po4 on the switch?
I have a 2911 Router here and a 3750 switch with a L3 etherchannel and the config is as follows:
Switch
description Uplink to Cisco Router
no switchport
no ip address
channel-group 9 mode on
interface GigabitEthernet1/0/2
no switchport
no ip address
interface Port-channel9
no switchport
ip address 10.10.10.2 255.255.255.252
end
Router
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
channel-group 9
no ip address
duplex auto
speed auto
channel-group 9
ip address 10.10.10.1 255.255.255.252
ip virtual-reassembly in
hold-queue 150 in
end
