Warning message
CISCO WLC How to Block a Client
Dec 25th, 2013
We are using CISCO WLC and broadcasting a number of SSIDs.
What we want to do is to block some spesific users to a spesific SSIDs while letting to connct to another SSID.
Dows anyone have any idea?
Scott Fella Thu, 12/26/2013 - 04:56
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You can use radius 802.1x authentication or you can setup Mac filtering on the WLC and specify what WLAN's they can connect to. They will only be able to connect to one SSID though.
This setup you have is not normal as you want to have a device only connect to one ssid for simplicity and for user experience. Having the be able to connect to multiple
SSID's can lead to connectivity issues on the client side, since the device might switch back and fourth to the different SSID's. Also the more SSID's you have the more noise in the environment. Typically 3-4 max SSID's is suggested.
Sandeep Choudhary Thu, 12/26/2013 - 12:13
  • Purple, 4500 points or more
    2017 Wireless
adding to Scott...
You can configure MAC Filtering under WLAN section for a specific SSID/WLAN.
You can configure list of mac addresses under MAC Filtering section under security tab and once done just select MAC Filtering option check box under WLAN Tab for specific SSID.
Have a look at this link
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70wlan.html#wp1084782
Dont forget to rate helps.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
