Warning message
3850 QoS question
Answered Question
Dec 26th, 2013
I am trying to upgrade from 3750 to 3850. Following is my outbound WTD qos config on 3750:
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 1 2 4
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 46
mls qos srr-queue output dscp-map queue 2 threshold 1 16 18 20 22 32 34 36 38
mls qos srr-queue output dscp-map queue 2 threshold 2 24 26 28 30
mls qos srr-queue output dscp-map queue 2 threshold 3 48 56
mls qos srr-queue output dscp-map queue 3 threshold 3 0
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 3 4 10 12 14
mls qos queue-set output 1 threshold 2 70 80 100 100
mls qos queue-set output 1 threshold 4 40 100 100 100
What will be the equivalent config for the 3850? I am not able to find the right documentation for 3850.
Following is what I created but I believe it wouldnt handle WTD.
class-map match-any EF
match dscp ef
class-map match-any CS3AF41
match dscp cs3 af41
class-map match-any AF21
match dscp af21
class-map match-any AF11
match dscp af11
class-map match-any Default
match dscp default
policy-map QOS-OUTBOUND
class EF
   priority level 1
class CS3AF41
   priority level 2
class AF21
   bandwidth remaining percent 20
   shape average percent 100
class AF11
class Default
   bandwidth remaining percent 60
Also, when I try to apply this to an interface, it accepts it but its not visible under show runn. Am I missing anything?
I would appreciate any help with this.
Thank you.
Correct Answer by Rasika Nayanajith about 3 years 7 months ago
3850 is not supporting MLS QoS (so any QoS commands start with mls keyword is not applicable in this switch platform- even thoug they are accepted).
It is a MQC QoS based switch platform (like 6500,4500). There are few Queing models (1P7Q3T, 2P6Q3T for wired &  2P2Q for wireless) supported in this platform. Please refer below post for more detail
http://mrncciew.com/2013/12/23/3850-qos-part-2-queuing-models/
Based on this you need to derive your config changes. As you can see in the above "queue limit x " is the command used to configure WTD for non-priority queues (ie Q2 to Q6)
Regarding running config, you can use "show running-config all" command to see all the configuration lines of your switch including default configs
Rasika
***Pls rate all useful responses ****
Overall Rating: 5 (1 ratings)
Correct Answer
Rasika Nayanajith Sat, 12/28/2013 - 14:40
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Rasika
Related Content
