Warning message
Call speeds.
Dec 27th, 2013
I give a mxp 95 at a far location over a satellite link at 512 k. When I try to establish a call to it from the mcu the max rate the call will establish at is 192k. There is no max bandwidth set on the codec or mcu. Any ideas
Patrick Pettit Fri, 12/27/2013 - 13:07
  • Cisco Employee,
Hard to tell. You can run xcon and xstat to see the config and status of the system. Then run: syslog on, place the call so we can see whats be requested in both directions for BW etc. Should to see. 192 for video? What audio codec is in use?
VR
Patrick
Sent from Cisco Technical Support Android App
Wayne DeNardi Sun, 12/29/2013 - 15:10
  • Green, 3000 points or more
  • Cisco Designated VIP,
    2017 TelePresence
Hi Paul,
Does the call estabish at a different rate if your dial it in the opposite direction (endpoint to MCU)?  Could help to pinpoint where the cause of the issue is, on the endpoint, or on the MCU, or something else?
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Related Content
