Warning message
AP801AGN radios reset when both enabled
Dec 27th, 2013
I have an AP801AGN set to unified mode.  I have it connected to a 5508 running IOS 7.4.103.7.  When I have both radios enabled, I get this:
*Dec 27 15:29:41.051: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Dec 27 15:29:42.019: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Dec 27 15:29:42.231: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Dec 27 15:29:42.835: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Dec 27 15:29:43.835: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Dec 27 15:30:00.267: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec 27 15:30:01.447: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec 27 15:30:02.043: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec 27 15:30:02.075: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Dec 27 15:30:03.043: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Dec 27 15:30:03.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Dec 27 15:30:03.859: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
And it just keeps going like that.
When I disable one radio, it does not matter which one, the other one comes up, and stays up.
Please let me know what needs to be done to have both radios up at the same time.
Scott Fella Fri, 12/27/2013 - 08:36
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
What I would do and I have had issues with my 1941w when upgrading. I would delete the image from flash and install the rcv image and have the AP801 join and download the new firmware. That code you are running is a TAC release and maybe the image is corrupt for the AP801. You will have to test that by deleting the image and having the AP download the code again.
This is how I fixed my issues which you are having. Some beta codes I have used never worked because of the AP801 image being corrupt. The v7.4 both versions, v7.5.102.0 and v7.6.100.0 all work fine with my AP801.
scottsassin Fri, 12/27/2013 - 08:44
Thanks Scott,
I will try upgrading the WLC IOS, and let you know what happens.
Scott Fella Fri, 12/27/2013 - 08:53
  • Hall of Fame,
    2017 Wireless
If your going to upgrade, then I would suggest using v7.4.121.0 which is MR2.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
Leo Laohoo Fri, 12/27/2013 - 14:49
  • Hall of Fame,
    2017 LAN, Wireless
Post the output to the following commands:
1.  WLC:  sh sysinfo
2.  AP:  sh version; and
3.  AP:  dir
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
