Touch Controller pairing timeout
Answered Question
Dec 27th, 2013
Hello!
Could you please help me... Is there a command or way to reduce the timeout of pairing between TC and SX-20, because when restart the both devices, it takes around 2minutes for pairing.
I'll appreciate your help, Regards
Correct Answer by Teck Chye Tang about 3 years 7 months ago
There is no user available command to configure the pairing timeout.  The touch will keep trying to pair with the previously known codec until succesfully paired or until you intervene and try to paired to other codecs.
Overall Rating: 5 (1 ratings)
Correct Answer
Teck Chye Tang Wed, 01/01/2014 - 19:00
  • Cisco Employee,
Phill Daniel Sun, 03/16/2014 - 12:51
dont know if it reduces time in your case - but do you have static IP's assigned to both the SX20 and the Touchpanel?  if either has DHCP then i presume completing the pairing process could take longer
