Warning message
486 Busy Here
Answered Question
So yesterday I had a fully functioning Cisco CME with a Callcentric SIP trunk, and today incoming calls are failing with a "486 busy here" message.  I can make outgoing calls with no problem.  Nothing has changed in the config since it was working.
Here is debug ccsip messages:
*Dec 28 19:33:47.663: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:[email protected]:5060 SIP/2.0
v: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-7b2878d04ec1f664c1468281f717aca8
f: "Cell Phone   ME" <sip:[email protected]>;tag=3597248031-456692
t: <sip:[email protected]>
i: [email protected]
CSeq: 1 INVITE
Max-Forwards: 8
m: <sip:[email protected]:5080;transport=udp>
Supported: timer
c: application/sdp
l: 364
v=0
o=NexTone-MSW 15835 13386 IN IP4 204.11.192.159
s=sip call
c=IN IP4 204.11.192.159
t=0 0
m=audio 59388 RTP/AVP 0 18 96 101
a=maxptime:30
a=sendrecv
a=fmtp:101 0-15
a=rtpmap:101 telephone-event/8000
a=fmtp:96 mode=30
a=rtpmap:96 iLBC/8000
a=fmtp:18 annexb=no
a=rtpmap:18 G729/8000
a=rtpmap:0 PCMU/8000
a=silenceSupp:off - - - -
a=setup:actpass
*Dec 28 19:33:47.687: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Se
GMIT-VOICEROUTnt:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-7b2878d04ec1f664c1468281f717aca8
From: "Cell Phone   ME" <sip:[email protected]>;tag=3597248031-456692
To: <sip:[email protected]>
Date: Sat, 28 Dec 2013 19:33:47 GMT
Call-ID: [email protected]
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
SIP/2.0 486 Busy here
To: <sip:[email protected]>;tag=280830-25F5
CSeq: 1 INVITE
Reason: Q.850;cause=17
Content-Length: 0
*Dec 28 19:33:47.751: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:[email protected]:5060 SIP/2.0
t: <sip:[email protected]>;tag=280830-25F5
CSeq: 1 ACK
Max-Forwards: 10
l: 0
ER01#
GMIT-VOICEROUTER01#
*Dec 28 19:33:53.003: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:[email protected]:5070 SIP/2.0
v: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-6dcd081ae68ebfe2658fc27a157e44d0
CSeq: 1 ACK
Max-Forwards: 8
l: 0
Correct Answer by Carlo Poggiarelli about 3 years 7 months ago
Hi Eric
Can you try this for me and send a debug ccisip messages?
num-exp 17772882353 7011
see if you can dial 17772882353 from outside
Please let me know
Carlo
Overall Rating: 4 (2 ratings)
Suresh Subramanian Sun, 12/29/2013 - 23:13
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, October 2015
is this happening for a particular phone or all phones?
could you please collect below debugs?
debug ephone detail
debug voip ccapi inout
debug ccsip message
Carlo Poggiarelli Mon, 12/30/2013 - 03:50
  • Green, 3000 points or more
Hi Eric.
Checking your config on your previous thread, can you please change ephone-dn 82 to dual-line?
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Here are the debugs from an inbound call that fails with "party unavailable" recording:
debug ephone detail
This may severely impact system performance. Continue? [confirm]d
GMIT-VOICEROUTER01#ebug voip ccapi inout
% Invalid input detected at '^' marker.
GMIT-VOICEROUTER01#debug     debug voip ccapi inout
voip ccapi inout debugging is on
GMIT-VOICEROUTER01#debug ccsip message
SIP Call messages tracing is enabled
GMIT-VOICEROUTER01#
*Dec 30 16:52:50.816: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 204.11.192.160:5080;branch=z9hG4bK-78ba91246ea68b8e61d707aa505fa828
f: "Cell Phone   ME" ;tag=3597411176-875822
t: [email protected]>
CSeq: 1 INVITE
Max-Forwards: 8
m:
Supported: timer
c: application/sdp
l: 364
v=0
o=NexTone-MSW 26817 24764 IN IP4 204.11.192.160
s=sip call
c=IN IP4 204.11.192.160
t=0 0
m=audio 61240 RTP/AVP 0 18 96 101
a=maxptime:30
a=sendrecv
a=fmtp:101 0-15
a=fmtp:96 mode=30
a=fmtp:18 annexb=no
a=setup:actpass
*Dec 30 16:52:50.824: //6766/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
GMIT-VOICEROUTCall Entry Is Not Found
*Dec 30 16:52:50.824: //-1/A7330314814B/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=12072277649
   ----- ccCallInfo IE subfields -----
   cisco-ani=12072277649
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=17772882353
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Dec 30 16:52:50.824: //-1/A7330314814B/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x494F8810, Call Info(
   Calling Number=12072277649,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=17772882353(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=700, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=6766
*Dec 30 16:52:50.828: //-1/A7330314814B/CCAPI/ccCheckClipClir:
   In: Calling Number=12072277649(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=12072277649(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Dec 30 16:52:50.828: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 30 16:52:50.828: :cc_get_feature_vsa malloc success
*Dec 30 16:52:50.828:  cc_get_feature_vsa count is 1
*Dec 30 16:52:50.828: :FEATURE_VSA attributes are: feature_name:0,feature_time:1289480888,feature_id:57
*Dec 30 16:52:50.828: //6766/A7330314814B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=12072277649(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=17772882353(TON=Unknown, NPI=Unknown))
*Dec 30 16:52:50.832: //6766/A7330314814B/CCAPI/cc_process_call_setup_ind:
   Event=0x4A2CDF80
*Dec 30 16:52:50.832: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 17772882353
*Dec 30 16:52:50.836: //6766/A7330314814B/CCAPI/ccCallSetContext:
   Context=0x47DD3408
*Dec 30 16:52:50.836: //6766/A7330314814B/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 6766 with tag 700 to app "_ManagedAppProcess_Default"
*Dec 30 16:52:50.840: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.160:5080;branch=z9hG4bK-78ba91246ea68b8e61d707aa505fa828
To: [email protected]>
Date: Mon, 30 Dec 2013 16:52:50 GMT
CSeq: 1 INVITE
Content-Length: 0
*Dec 30 16:52:50.840: //6766/A7330314814B/CCAPI/ccCallProceeding:
*Dec 30 16:52:50.844: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Dec 30 16:52:50.844: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Dec 30 16:52:50.844: : updating existing feature vsa
*Dec 30 16:52:50.844:  feature call basic
*Dec 30 16:52:50.844: //6766/A7330314814B/CCAPI/ccCallDisconnect:
   Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
*Dec 30 16:52:50.848: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: [email protected]>;tag=990BDC8-214E
CSeq: 1 INVITE
Content-Length: 0
*Dec 30 16:52:50.904: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
t: [email protected]>;tag=990BDC8-214E
CSeq: 1 ACK
Max-Forwards: 10
l: 0
*Dec 30 16:52:50.904: //6766/A7330314814B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x494F8810, Tag=0x0, Call Id=6766,
   Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Dec 30 16:52:50.904: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 30 16:52:50.908: :cc_free_feature_vsa freeing 4CDBEAB0
*Dec 30 16:52:50.908: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 30 16:52:50.908:  vsacount in free is 0ER01#
GMIT-VOICEROUTER01#
*Dec 30 16:53:07.172: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 204.11.192.160:5080;branch=z9hG4bK-9ccc81ceef0a0001bb1ed78a4455f6bb
f: "Cell Phone   ME" ;tag=3597411193-215572
CSeq: 1 INVITE
Max-Forwards: 8
m:
Supported: timer
c: application/sdp
l: 364
v=0
s=sip call
t=0 0
m=audio 61256 RTP/AVP 0 18 96 101
a=maxptime:30
a=sendrecv
a=fmtp:101 0-15
a=fmtp:96 mode=30
a=fmtp:18 annexb=no
a=setup:actpass
*Dec 30 16:53:07.180: //6767/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
*Dec 30 16:53:07.184: //-1/B0F35A4D8150/CCAPI/cc_api_display_ie_subfields:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=17772882353
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Dec 30 16:53:07.184: //-1/B0F35A4D8150/CCAPI/cc_api_call_setup_ind_common:
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=6767
*Dec 30 16:53:07.184: //-1/B0F35A4D8150/CCAPI/ccCheckClipClir:
*Dec 30 16:53:07.184: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 30 16:53:07.184: :cc_get_feature_vsa malloc success
*Dec 30 16:53:07.188:  cc_get_feature_vsa count is 1
*Dec 30 16:53:07.188: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Dec 30 16:53:07.188: :FEATURE_VSA attributes are: feature_name:0,feature_time:1289480888,feature_id:58
*Dec 30 16:53:07.188: //6767/B0F35A4D8150/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
*Dec 30 16:53:07.188: //6767/B0F35A4D8150/CCAPI/cc_process_call_setup_ind:
   Event=0x4A2CDF80
*Dec 30 16:53:07.188: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Dec 30 16:53:07.188: //6767/B0F35A4D8150/CCAPI/ccCallSetContext:
   Context=0x47DD5A18
*Dec 30 16:53:07.192: //6767/B0F35A4D8150/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 6767 with tag 700 to app "_ManagedAppProcess_Default"
*Dec 30 16:53:07.192: //6767/B0F35A4D8150/CCAPI/ccCallProceeding:
*Dec 30 16:53:07.196: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Dec 30 16:53:07.196: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Dec 30 16:53:07.196: : updating existing feature vsa
*Dec 30 16:53:07.196:  feature call basic
*Dec 30 16:53:07.196: //6767/B0F35A4D8150/CCAPI/ccCallDisconnect:
*Dec 30 16:53:07.200: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.160:5080;branch=z9hG4bK-9ccc81ceef0a0001bb1ed78a4455f6bb
Date: Mon, 30 Dec 2013 16:53:07 GMT
CSeq: 1 INVITE
Content-Length: 0
Sent:
To: [email protected]>;tag=990FDA8-DF8
CSeq: 1 INVITE
Content-Length: 0
*Dec 30 16:53:07.260: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
t: [email protected]>;tag=990FDA8-DF8
CSeq: 1 ACK
Max-Forwards: 10
l: 0
*Dec 30 16:53:07.260: //6767/B0F35A4D8150/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x494F8810, Tag=0x0, Call Id=6767,
*Dec 30 16:53:07.264: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Dec 30 16:53:07.264: :cc_free_feature_vsa freeing 4CDBEAB0
*Dec 30 16:53:07.264:  vsacount in free is 0
*Dec 30 16:53:08.372: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 204.11.192.160:5080;branch=z9hG4bK-c1461a555741ac74cd4bd429f69f3c0f
CSeq: 1 ACK
Max-Forwards: 8
l: 0
ER01#
GMIT-VOICEROUTER01#no debug all
All possible debugging has been turned off
GMIT-VOICEROUTER01#
Correct Answer
Carlo Poggiarelli Tue, 12/31/2013 - 10:21
Hi Eric
Please let me know
Carlo
Carlo Poggiarelli Tue, 12/31/2013 - 14:43
Hi Eric.
Glad to know that now all is working.
Happy New Year!!!
Carlo
