Warning message
Blocking a MAC from getting IP from ASA DHCP
Dec 30th, 2013
WE use ASA as remote VPN and use DHCP pool on this ASA. Is it possible to block a specific MAC from getting IP from this pool?
thanks,
Han
Collin Clark Mon, 12/30/2013 - 09:34
  • Purple, 4500 points or more
If you block it from getting DHCP from a pool then where do you want it to get an IP from? Another pool? Local?
hanwucisco Mon, 12/30/2013 - 10:44
Collin,
We simply dont want it get to the VPN to the network. Any method that we can block this mac would be great, but login here is not an option.
thanks,
Han
Collin Clark Mon, 12/30/2013 - 18:57
Hmmmm, I guess what I would do is create a static reservation with an IP that's not valid, like 169.254.254.
abcdrohan Wed, 01/01/2014 - 19:01
How about creating an arp entry for the ip
For e.g. The ip is 1.1.1.1 on the inside with Mac address xxxx and 1.1.1.0/24 is the dhcp pool. You don't want to hand out 1.1.1.1 via dhcp
Then you add an entry
Arp inside 1.1.1.1 xxxx
So that Asa excludes 1.1.1.1 from being handed out via dhcp
