spa504g with netgear router DGN2200v4
Dec 30th, 2013
I have a spa504g ip phone with a netgear router DGN2200v4.
I have been told by netgear that their router does not
support IP Phones...however I find this hard to believe.
I have set up the phone through a secondary Cisco router (used
only to create another wireless access point on 1 of 3 floors).
Bottom line I know I need to indicate in phone setup the IP address of main router
which is netgear however when I do that my internet access
goes down and I need to reboot netgear router.
Any suggestions on how I need to configure the phone to avoid
netgear router from freezing?
Jaime Valencia Tue, 12/31/2013 - 08:10
  • Cisco Employee,
  • Hall of Fame,
    2011
SPAs are SMB products, you should ask this in the SMB community.
Not even sure why you're asking this in the Video Over IP section???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
