Symbol MC9090 Scan Guns- 2602i AP's/5508
Dec 31st, 2013
We have used the Symbol Scan guns for quite some time on our wireless networks.  Recently we upgraded a location that had Cisco 1242 AP's, to the newer 2602i model.  The controller is a 5508 on version 7.3, and the access points are operating in FlexConnect mode.
Since upgrading to the 2602i AP's. we have had many issues with the Symbol MC9090 scan guns.  They appear to be roaming very frequently between AP's servicing this area.  At first we thought it was coverage, and added more access points.  We are still seeing the same problems.  The signal strength fluctuates on the scan gun from excellent to poor very often, and I notice packets getting dropped during this process.
The application runnig on the scan gun will halt, and either normailze or cause the device to have to be completely reset.  These problems were not happenng before we upgraded to the new model of AP.  I have read the document Cisco published concerning best practices for Symbol/Motorola scanners and controller based networks, but that is fairly old and out of date.  We do have CCKM, Aironet IE, and Band Select enabled on this WLAN.  I assume I should probably disable these features but we have other scan guns using this same WLAN with no problems.  The biggest change was when we went from the 1242 to the 2602i.  During this change, we also moved also from a controller where the AP's were in local mode, to now the access points operating in Flex connecting to a central controller.  Latency between the AP's and the controller is not a problem.
Any help would be greatly appreciated.
Overall Rating: 4.8 (6 ratings)
Leo Laohoo Tue, 12/31/2013 - 16:27
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Check the manufacturer's website for any recent addition to the drivers of the guns.  The decision to associate to APs is the responsibility of the client and not the AP.
Can you specify what data rates are your radios operating on?
Could you also verify that TPC and/or DCA are enabled and set to auto?  And refresh is set to, say, 12- or 24-hours?
awatson20 Tue, 12/31/2013 - 17:27
We are going to start with trying to update the Client drivers.
TPC and DCA is enabled and set to auto.  Interval is 10 minutes. I have turned up the transmit power manually on some of these access points in an effort to try and improve the issue.  I typically do not do this. but I noticed that RSSI was weak in some areas, and the transmit power on the access points were turned down on 5 and 6.
The Data rates for 802.11b/g/n are:
1 Mandatory
2 Mandatory
5.5 Mandatory
6 Supported
9 Supported
11 Mandatory
12 Supported
18 Supported
14 Supported
36 Supported
48 Supported
54 Supported
Leo Laohoo Tue, 12/31/2013 - 22:47
  • Hall of Fame,
    2017 LAN, Wireless
Don't do all.  Just a few.  About three or four and test.  If you see some improvements, then roll it out.
I'm not sure about the others but this is too low.  I normally set mine (if I recall) to 12 hours.
Don't.  Leave them all to auto.  Again, make sure the refresh value is long.
Rasika Nayanajith Tue, 12/31/2013 - 23:31
  • Purple, 4500 points or more
    2017 Wireless
Disable all data rates given below & make 12Mbps as mandatory in 2.4GHz band (Unless you have client operate in 802.11b only). You have default configuration for these & it is not optimum. By doing this you can get performance enhancement as well.
1 Mandatory
2 Mandatory
5.5 Mandatory
6 Supported
9 Supported
11 Mandatory
DCA interval 10 min is default setting. I have set it to 8 hours in my environment which acnhor it to 8:00AM.
Rasika
***** Pls rate all useful responses ****
Vasco Costa Thu, 06/05/2014 - 03:27
We've got a similar problem with old scan guns working with WEP on a 2602i APs+WLC 5760 environment.
We mitigate the problem by implementing this solution (disable all <12Mb's) and manually adjust the RRM values of some APs.
awatson20 Wed, 01/01/2014 - 07:42
Can DCA changes and Data rates be modified specifically for these access points and not globally on the WLC? This WLC services many other AP's. Would this be done as an RF profile then applied to an AP group?
Scott Fella Wed, 01/01/2014 - 08:20
  • Hall of Fame,
    2017 Wireless
Data rates can be configured with using RF Groups and AP Groups in combination.  I believe in v7.4, RF Groups were available.  DCA can only be set globally.  It is recommended that you have set the DCA interval to 24 hours and not leave it at 10 minutes which is default.
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/consolidated/b_cg74_CONSOLIDATED_chapter_010000101.html
As far as the issues you are seeing, your scanners roaming aggressively.... how is the RF environment.... was a site survey done?  The reason I say this is because I have heard customers complain about this and it was due to lack of coverage and devices looking to roam more frequently that what it should.  If you have the default data rates and your RF coverage is at the required specifications, < -72 rssi everywhere and > -20dbi for SNR, your client should stick since the lowest mandatory rate is 1mbps.
So can you tell us if a site survey was done and what was the requirement of the site survey?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
awatson20 Wed, 01/01/2014 - 09:42
Yes, a site survey was performed.  Originally, we had 1242 AP's in this area.  We started having problems when we replaced the 1242 AP's with external antennas, with the 2602I using internal antennas.  In most environments where we have made this transition, a 1 for 1 replacement usually works ok.  At this particular location, we added some additional access points to address what we thought could be a coverage issue.
I have not adjusted the global TPC settings, but we did adjust the power level on these access points as it seemed RRM had the power adjusted way down.  The access points Tx Power Level assignment was auto set to 5 and 6 on most of these access points.  Should we leave this to auto?  I have seen in some environments, and depending on the client, adjusting the power level helped with coverage.
In looking at client session reports in Prime/NCS, we see that client RSSI and SNR for this area over a period of time is averaging -62 RSSI and SNR 31dbi. There are some areas that these clients are reporting higher RSSI over -75, and we may need to add coverage.  However it appeared to be working fine with the 1242 and less AP's.
From the Scan Gun perspective, when it roams or when the RSSI gets high, the application will freeze momentairly, but we do not lose connectivity.  I plan on spending some time tomorrow doing another thorough site survey to see what is going on.
George Stefanick Wed, 01/01/2014 - 09:46
  • Community Spotlight Award,
    Best Publication, October 2015
One thing I would do is a client debug and reproduce your problem.
Scott Fella Wed, 01/01/2014 - 10:12
  • Hall of Fame,
    2017 Wireless
Well a 1 to 1 replacement with different antennas will change you RF footprint. When you see RRM set TX to 5-6, it's due to the AP's being high and in line of site to each other. This means that the RF at that height is fine, but at floor level it's not. I would set the MIN TX level to 11dbm or 14dbm under the TPC settings. You will need to disable the radio to make these changes. This usually fixes the issues in my customers environment. Adding more AP's and letting RRM handle changes will cause the TX power to drop even more. So when I see TX power at what you have, it tells me that you should have coverage, but not knowing the attenuation from racks and product, you just need to tweak your TPC. You can set the MAX TX power to 20dbm or 17dbm depending what your coverage requires. You can set these parameters and put a scanner in site survey mode, if they have that, and look at your signal and or available APs in the area. This way you can look at some trouble spots and determine if the power needs to be higher or not. Maybe due to attenuation, another AP might need to be installed. We usually do a post site survey to see if the coverage has changed and to determine areas that might have to be tweaked manually.
awatson20 Wed, 01/01/2014 - 10:48
Thanks.  That is the same thing we thought.  Based on those levels, it appeared we did have enough coverage.  We have had to modify the Tx power in warehouses where the AP's were mounted high in the ceiling.  In this scenario, there is a lot of racking and dense product in this area.
In regards to your suggested changes below, are you referring to changing this per radio, as in adjusting the Tx power level assignment to 1 or 2? Or is this a global change under RRM TPC configuartion you are referring to?
Scott Fella Wed, 01/01/2014 - 11:26
  • Hall of Fame,
    2017 Wireless
I would set it globally on the 802.11 radios for TPC. I would see how that works first and then you might have to set it manually if you still see issues. You can set the MIN to 14 or higher is you want, this just prevents the AP from lowering power past the specified TX value you set.
Rasika Nayanajith Tue, 12/31/2013 - 14:33
    2017 Wireless
Is it possible to check these AP in local mode & see problem persist ? In that way you can isolate this issue is with FlexConnect or not
I would suggest you to move to a later code like 7.4.121.0 (7.4MR2 release) with FUS upgrade to 1.7.0.0 as that is the code I would recommend to anyone.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn74mr02.html
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/fus_rn_1_7_0_0.html
Rasika
**** Pls rate all useful responses *****
Mats Nilson Mon, 02/17/2014 - 05:06
Hi Guys.
I was searching this forum for somone that is experiencing similar problems as we have currently.
We are using Autonomous 2602e with standard "rubber duck" antennas (AIR-ANT2524DB-R=) and Motorola MC17 and MK4900 wireless units. The clients (even stationary) are roaming excessively and have poor performance in wireless connectivity. RF is good(SNR and signal levels)
We have tried tuning the powerlevels to match the client. Other sites with (almost)identical configuration and environment (switches, vlans, firmware, etc) but with 1242AGN work excellent!
Client is roaming excessively without any apparent reason. When comparing 1242, the 2602 has spectrum intelligence and other RF enhancing function, but these are not activated. We have disabled 802.11n and speeds below 5.5Mbs(basic) the rest supported.
********* Config ***********
Current configuration : 5451 bytes
version 15.2
no service pad
service timestamps log datetime localtime
service password-encryption
hostname XXXXXXX
logging rate-limit console 9
aaa new-model
aaa group server radius rad_eap
server X.X.X.X
aaa group server radius rad_mac
server X.X.X.X
aaa group server radius rad_acct
server X.X.X.X
aaa group server radius rad_adm
server X.X.X.X
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods group rad_mac
aaa authentication login admin group rad_adm local
aaa authentication enable default group rad_adm enable
aaa accounting exec default stop-only group rad_acct
aaa accounting network acct_methods stop-only group rad_acct
aaa session-id common
clock timezone +0100 1 0
no ip routing
ip domain name net.axfood.se
ip name-server X.X.X.X
dot11 syslog
dot11 vlan-name equipment vlan 60
dot11 vlan-name selfscanning vlan 40
dot11 vlan-name voice vlan 20
dot11 vlan-name default vlan 1
dot11 ssid EQUIPMENT
   vlan 60
   authentication open
   authentication key-management wpa
   wpa-psk ascii 7 X.X.X.X
dot11 ssid SCANNING
   vlan 40
   authentication open
   authentication key-management wpa version 1
dot11 wpa handshake timeout 2000
dot11 network-map
power inline negotiation prestandard source
username @@@@@@ privilege 15 password 7 XXXXX
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 40 mode ciphers tkip
encryption vlan 60 mode ciphers tkip
ssid EQUIPMENT
ssid SCANNING
antenna gain 0     <--- I know this is wrong; should be 2 (AIR-ANT2524DW-R=)
stbc
speed  basic-5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
power local 11
power client local
packet retries 128 drop-packet
channel least-congested 2412 2437 2462
station-role root
rts retries 128
no dot11 extension aironet
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 spanning-disabled
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
interface Dot11Radio0.40
encapsulation dot1Q 40
no ip route-cache
bridge-group 40
bridge-group 40 subscriber-loop-control
bridge-group 40 spanning-disabled
bridge-group 40 block-unknown-source
no bridge-group 40 source-learning
no bridge-group 40 unicast-flooding
interface Dot11Radio0.60
encapsulation dot1Q 60
no ip route-cache
bridge-group 60
bridge-group 60 subscriber-loop-control
bridge-group 60 spanning-disabled
bridge-group 60 block-unknown-source
no bridge-group 60 source-learning
no bridge-group 60 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0     <--- I know this is wrong; should be 4 (AIR-ANT2524DW-R=)
no dfs band block
channel dfs
station-role root
no cdp enable
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.40
no ip route-cache
bridge-group 40
interface GigabitEthernet0.60
no ip route-cache
bridge-group 60
interface BVI1
ip address X.X.X.X 255.255.255.0
no ip route-cache
ip default-gateway X.X.X.X
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging X.X.X.X
access-list 111 permit tcp any any neq telnet
snmp-server community XXxxxXX RW
radius-server attribute 32 include-in-access-req format %h
radius-server dead-criteria time 10 tries 3
radius-server host X.X.X.X key 7 DDDDdddddDDDDD
radius-server host X.X.X.X key 7 bbbbBBBBBbbbbb
radius-server retransmit 2
radius-server timeout 4
radius-server deadtime 1
radius-server vsa send accounting
bridge 1 route ip
line con 0
access-class 111 in
password 7 ppppppppPPPPppppppp
logging synchronous
login authentication admin
history size 50
line vty 0 4
access-class 111 in
logging synchronous
history size 50
transport input ssh
line vty 5 15
exec-timeout 3 0
history size 50
transport input ssh
sntp server X.X.X.X
sntp broadcast client
end
Is there any "hidden" rate, access limiting or load-balancing features on the 2602 access points?
This is causing major disruptions on the stores where the 2602e access points have been deployed.
Checking the the client statistics for signal and SNR gives no reason why stationary clients should roam unless the access points fails to acknowledge reassociation requests from the client.
One important information is that many simultaneous association requests for some access points due to the fact that many motorola devices(50-200) are aggregated in racks.
Sincere Regards
Any ideas?
Dominic Stalder Thu, 03/13/2014 - 05:16
Hi there
Have you been able to solve your problem? A customer of us are experiencing exactly the same issues.
What authentication / encryption are you using?
Thanks in advance and regards Dominic
awatson20 Thu, 03/13/2014 - 05:30
We are doing EAP-TLS with WPA2/AES.  We modified the data rates which seemed to help.  Also, we upgraded to a newer Scan Gun Model (MC92N) which has 802.11n capabilities and that helped.  But ultimately, the fix was having the application modifed to be better suited for a wireless envrionement.  This incldued adjusting time-out settings in the app.
Steven Anderson Mon, 01/23/2017 - 08:55
The cause is the software on the scanners. Call Zebra to get the latest Fusion software release for your device.
MC92N0
Below is an excerpt from the release notes stating a roam stickiness issue. I resolved this issue for model MC92N0 by installing FUSION_X_2.03.0.0.012R_MPA3_WM65.CAB
Release Notes - Windows Mobile 6.5 - Fusion X_2.02.0.0.016R – SPR25781
"Roam stickiness caused by state machine bug causing roam scans to fail. Device fails to roam to AP with good signal strength and stays connected to AP with very low signal strength."
https://www.zebra.com/content/dam/zebra_new_ia/enus/software/utilities/f...
MC9190
The MC9190 has a bug fix for roaming too frequently. This software release fixes the issue: Fusion_3.00.2.0.025R_WM65.ARM.CAB
Release Notes - Windows Mobile 6.5 - Fusion 3.00.2.0.025R
"SPR 20363 – WLAN roams frequently in an environment where AP beacons are sent at 11 Mbps (i.e. the lowest basic rate on the AP is set to 11 Mbps)."
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
