Warning message
Wireless
Answered Question
Jan 1st, 2014
Dear Sir,
i have cisco 2500 series wireless controller i want to add one cisco 1140 Access point on that controller
what steps i need to take firmware need to upgrade
Correct Answer by Scott Fella about 3 years 7 months ago
Kamal,
I'm order to help us understand the issue, you need to console into that AP and post the output so we can see if your performing the upgrade properly.
There are any docs that explain the sets and some videos. Make sure your using A compatible TFTP server. I use 3CDeamon and have not have any issues. Also make sure that your firewall is disabled on you machine as tftp is usually being blocked. Here are some links to documents and a video that you can follow to upload image to any Cisco indoor access point.
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/u...
https://supportforums.cisco.com/docs/DOC-18268
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
Correct Answer by Sandeep Choudhary about 3 years 7 months ago
HI Kamal,
As per my Knowledge u can not convert with WLC:
You should only need to pull the LWAPP/CAPWAP recovery image from cisco.com.  Then you can either use the upgrade tool or the  archive download command to pull and load the software onto the AP.
KAMAL MISHRA wrote:
Dear sir,
standalone access point output
sh inventory
NAME: "AP1140", DESCR: "Cisco Aironet 1140 Series (IEEE 802.11n) Access Point"
PID: AIR-LAP1142N-A-K9
sh version
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 58:8D:09:59:30:E2
Sir above is the ouput of standalone APS these are 1140 series
socan i migrate these access points with WLC 2500 series pls help
or what procedure i need to follow.
and controller side what configuration i need to done
U have IOS(aitonomous image- k9w7), u need to convert it to Lightweight AP(k9w8)
k9w7 - autonomous (or "site survey") IOS
k9w8 - full lightweight IOS (this is what is bundled in the WLC .aes image, and is factory installed on "mesh" APs)
rcvk9w8 - lightweight recovery image - this is factory installed on lightweight APs, unless a "mesh" image is specified; it lacks radio firmware.
http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
For the LWAP conversion, use the recovery image ( e.g  c1140-rcvk9w8-tar.,.......tar).
Correct Answer by Leo Laohoo about 3 years 7 months ago
Let's start with the basic, please post the output to the following commands:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
4.  AP:  sh ip interface brief; and
5.  AP:  sh inventory
Keep this handy to as this will show you what devices are supported on what code versions
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wire...
HI Kamal,
First of all which version u have on, paste the output from WLC: sh sysinfo
Also paste the output from AP: sh inventory
Steps to connect AP to WLC.
The AP's can be placed in any subnet you want. In order to make sure the AP's join the WLC in a different subnet, you need to at least have done one of these:
1. Initially place the AP's in the same subnet as the WLC management interface until the AP successfully joins. DHCP is required on this subnet for the AP. one joined, the AP will know of the WLC an then can be placed in any other subnet.
2. Use DHCP option 43 to point to the WLC management up address
3. On the L3 switch configure these global commands (either one depending on WLC code)
ip forward-protocol udp 5246
On the interface the AP's are on configure ip helper address pointing to the WLC management ip address.
also check this document : http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080665cdf.shtml
Dont forget to rate helpful posts.
Overall Rating: 5 (7 ratings)
Correct Answer
Sandeep Choudhary Sun, 01/05/2014 - 10:00
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
HI Kamal,
KAMAL MISHRA Sun, 01/05/2014 - 20:59
Thanks a lot sandeep
My AP is 11 40 series and my controller is 2500 series
AP is lightweight so need to upgrade ios or 2500 series controller direcly supports.
Sandeep Choudhary Mon, 01/06/2014 - 00:49
    2017 Wireless
HI Kamal, As in my first I and Leo also aksed about the Image on WLC:
Please paste the output of these commands:
WLC: sh sysinfo
AP: sh inventory
KAMAL MISHRA Fri, 01/10/2014 - 21:13
Thanks a lot sandeep i will provide the output of WLC also.
KAMAL MISHRA Sat, 01/11/2014 - 01:02
Dear sandip,
i will share the WLC output with you and again thanks a lot for ur support.
Correct Answer
Scott Fella Sun, 01/05/2014 - 11:18
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 Wireless
Correct Answer
Leo Laohoo Sun, 01/05/2014 - 12:40
  • Hall of Fame,
    2017 LAN, Wireless
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
5.  AP:  sh inventory
KAMAL MISHRA Fri, 01/10/2014 - 21:11
Dear sir,
sh inventory
sh version
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 18:09 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(18a)JA3, RELEASE SOFTWARE (fc1)
ICAP004 uptime is 3 weeks, 2 days, 48 minutes
System image file is "flash:/c1140-k9w7-mx.124-21a.JA1/c1140-k9w7-mx.124-21a.JA1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-LAP1142N-A-K9    (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FGL1442S594
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radio(s)
Leo Laohoo Fri, 01/10/2014 - 21:36
  • Hall of Fame,
    2017 LAN, Wireless
socan i migrate these access points with WLC 2500 series pls help or what procedure i need to follow.
What have you done with your WLC?
Correct Answer
Sandeep Choudhary Fri, 01/10/2014 - 23:03
    2017 Wireless
KAMAL MISHRA wrote:
Dear sir,
sh inventory
sh version
KAMAL MISHRA Fri, 01/10/2014 - 23:15
Thanks sandip,
so I need to upgrade mentioned image
c1140-rcvk9w8-tar on my access point.
KAMAL MISHRA Tue, 01/14/2014 - 03:08
Dear Sir,
My Access point is Cisco AIR-AP1142N-N-K9
currently it is stand alone now we are planning to migrate with our controller.
ICAP004#sh inventory
PID: AIR-LAP1142N-A-K9 , VID: V03, SN: FGL1442S594
ICAP004#sh version
so sir can we convert that access point stand alone to controller based.
[email protected].
2 802.11 Radio(s)
Part Number                          : 73-11451-08
PCA Assembly Number                  : 800-30554-06
PCA Revision Number                  : A0
PCB Serial Number                    : FOC14394VU4
Top Assembly Part Number             : 800-31273-04
Top Assembly Serial Number           : FGL1442S594
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1142N-A-K9
and tryning to convert into controller based
Correct Answer
Sandeep Choudhary Tue, 01/14/2014 - 03:33
    2017 Wireless
HI Kamal,
KAMAL MISHRA Tue, 01/14/2014 - 03:44
Dear Sir,
i have downloaded the image c1140-k9w8-tar.152-4.jb3 trying through tftp
but giving socket error
can u suggest that stand alone access point
we can migrate into controller based.
Sandeep Choudhary Tue, 01/14/2014 - 03:55
    2017 Wireless
Hi Kamal,
can you patse the command u r trying and please also paste the error.
Do you have WCS/NCS ?
KAMAL MISHRA Tue, 01/14/2014 - 04:25
Thanks sandeep still i am trying to upgrade but it is not done.
thaks a lot for your help i will share logs with you while upgrading the ios.
Correct Answer
Scott Fella Tue, 01/14/2014 - 04:42
  • Hall of Fame,
    2017 Wireless
Kamal,
