Warning message
Repoint IP Phones to new Call Manager
Answered Question
Jan 2nd, 2014
Version CUCM 7.1(5), our IP phones are deployed without DHCP, all phone IP and CM information is configured statically. In the near future we will be changing over to a new Call Manager (version 8 or 9 not sure which)  which will have different  IP address/subnet.  The current CM address was entered statically as the phones were deployed, but is it possible(or necessary) to rehome to the new CM address without going to each  physical location and changing the address statically?
Correct Answer by Jaime Valencia about 3 years 7 months ago
Other than using any of the 3rd party apps to control the phones remotely, yes, you'll need to change this directly on the phone.
I'm not even sure if there's a way to automate this via some SDK, you would need to check that in the developers forum.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 01/02/2014 - 08:00
  • Cisco Employee,
  • Hall of Fame,
    2011
java
will.alvord Fri, 01/03/2014 - 07:39
  • Silver, 250 points or more
It sounds like it'd be a lot easier to address the new server(s) with the same address(es).
bryantsteve Fri, 01/03/2014 - 08:10
Sure would, but unfortunately  not an option in this case
will.alvord Fri, 01/03/2014 - 08:32
Gotcha.  It's kludgy, but maybe a temporary nat so you could take your time with the static addressing of your endpoints?  Hopefully while touching each endpoint, you can go ahead and remove the static configs as well.  Hopefully your hands aren't tied there as well.  Guess Java's answer is the best choice you've got.  The macro feature of something like this (http://www.voipintegration.com/Software/Phone-Remote/) should make it a little less tedious.
