Warning message
SG300-10 switch commands not working
Jan 2nd, 2014
Hey guys
New to all this so be kind
I have an SG300-10 switch and have connected to the switch by telent and SSH, but when I run commands like 'enable' is tells me 'Unrecognized command'
The firmware is Version 1.3.0.62, I checked it looks like a new version is available, do I need to upgrade the firmware? If so are there any steps I need to follow to upgrade the firmware without bricking the switch?
EDIT: Ok so I tried the command conf t which worked, why does enable not work? Is it because the CLI is not IOS?
Matt
viningele Fri, 01/03/2014 - 03:46
Yep, the IOS commands have different levels.  You'll need to use the CLI command specific to the SG series since there are many differences.
