WPA2 Auth on WLC 5760 using ISE 1.2
fahadafzal
Hello there,
I am trying to configure WPA2 802.1x authentication on my WLC that should use ISE as radius server which is set to authenticate AD users.
The issue is that when I try to connect the SSID, it does not forward the authentication request to ISE. Therefore, I dont see any authentication request on ISE coming from the client.
I am using the following cli config for the SSID.
wlan TESTSTAFF 70 TESTSTAFF
aaa-override
client vlan Floor_WL
security dot1x authentication-list WPA-Auth
session-timeout 1800
no shutdown
aaa authentication dot1x WPA-Auth group ISE_Group
aaa group server radius ISE_Group
server name ISE
radius server ISE
address ipv4 <ise_ip> auth-port 1812 acct-port 1813
key <key>
On ISE, I have added the WLC as network device. CWA authentication is working fine it is just Layer2 WPA 802.1x authentication which is not forwarding requests to ISE.
Can you please suggest?
Thanks in advance.
Sandeep Choudhary
is ur wlc and iSE is connected???
is ur Radius Shared secret is correct or same on both side?
Please check these: http://www.cisco.com/en/US/products/ps11640/products_configuration_example09186a0080bead09.shtml
As I said, my all other authentication types are working between WLC, ISE and AD. I am facing issue only in 802.1x.
Pls check the following, that should help you
http://mrncciew.com/2013/12/16/configuring-radius-on-5760/
As Kasper said, I suspect you are missing dot1x system-auth control command
Rasika
**** Pls rate all useful responses ****
Kasper Roholt
Use the following global command on 5760:
dot1x system-auth-control
Rg
Kasper
