Warning message
wism cannot access through web
Jan 6th, 2014
Hi ,
One of the  wism controller in the module  cannot access throuh the web interface . ( ican access the second controller in the same module without any problem )
It may work after 2 -3 reboot or power off the module  for sometimes .After sometime the same problem happens
Operational Status of the Controller : Oper-Up
Modular switch model : C6513
Please help
Leo Laohoo Mon, 01/06/2014 - 01:42
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Post the output to the command "sh wism module X controller Y status".
support sbt Mon, 01/06/2014 - 01:59
Service VLAN                         : 200
Service Port                         : 9
Service Port Mac Address             : 001a.xxxx.xxxx
Service IP Address                   : 172.10.129.3
Management IP Address                : 10.0.2.10
Software Version                     : 4.2.207.0
Port Channel Number                  : 525
Allowed-vlan list                    : 14,27,37-41
Native VLAN ID                       : 27
WCP Keep Alive Missed                : 0
Leo Laohoo Mon, 01/06/2014 - 02:04
  • Hall of Fame,
    2017 LAN, Wireless
I think you need to upgrade the firmware of your controller.
This description is typical of a firmware bug.  If you need to choose a good version, go with 7.0.240.X.
Don't forget to upgrade the bootstrap.
support sbt Mon, 01/06/2014 - 02:25
We use ap1020 (aironet) , we tried to upgrade the controller  .Once the controller upgraded  AP'S are not connecting to the controller
Leo Laohoo Mon, 01/06/2014 - 02:31
  • Hall of Fame,
    2017 LAN, Wireless
Hmmmm ... Maybe the issue could be the version of your web browser.
Sandeep Choudhary Mon, 01/06/2014 - 02:04
  • Purple, 4500 points or more
    2017 Wireless
Can u please paste the output of the command: show network status
If you sse these commands is disabled then please enabled it agin :
WLC > config network ssh enable
WLC > config network webmode enable
WLC > config network secureweb enable
There was a bug in the wisms and the workaround  was to reload the controller.
If u have 2 wism then please Move over the APs and reload that WLC , that should fix it.
Hope it helps.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
