Warning message
Cisco SPA504G - network ports on the back -vlans
Jan 6th, 2014
I have some Cisco SPA504G phones which have Windows computers piggy backed off them using the PC port.
I want to seperate my VOICE and DATA into seperate VLANS.
I have a switch which has VLAN: 10 for VOICE and VLAN: 20 for DATA setup.
How do I go about setting the phone to use VLAN10 and the PC port on the Cisco phone to use the VLAN: 20 DATA?
Hermanus Janse ... Mon, 01/06/2014 - 04:47
  • Silver, 250 points or more
if your switch config looks like below the Phone and PC will get the correct VLAN:
interface FastEthernet1/0/2
switchport access vlan 20
switchport mode access
switchport voice vlan 10
spanning-tree portfast
unrealone1 Mon, 01/06/2014 - 04:59
Thanks for this. Does the phones need to be plugged into tagged ports? (sorry might be the HP term)
"interface FastEthernet1/0/2" What interface is this referring to?
No guru with cli, by configuring the switch as above, I just plug the phone into any port on the cisco switch?
Hermanus Janse ... Mon, 01/06/2014 - 05:02
on a cisco switch the ports is either fastethernet 1/0/1 or fastethernet 0/1 or gigbitethernet 0/1
so on CLI you need to enter conf t mode.
then go to the port number the phones is plugged into say for instance port 4 to port 8
then you can do
interface range fa0/4 - 8
exit
exit
wr
so yes you need to configure the ports on the cisco switch in which you plug the phones in.
