Cisco ASA TACACS+ enable mode not working
Answered Question
Jan 6th, 2014
I am configuring the ASA 8.4 with TACACS with below CLI configurations, I can only successfully login to the USER MODE of the ASA via TACACS, but unable to get to the enable mode of the ASA via TACACS. Also ASA is not falling to local enable password either.
Also I can successfully run the "test aaa authentication TACACS+ username abc password password1"
INFO: Authentication Successful
From same ACS TACACS works for both user mode and enable mode for routers/ switches.
Current ASA CLI
username [ENTER USERNAME HERE] password [ENTER ADMIN PASSWORD HERE] privilege 15
enable password [ENTER ENABLE MODE PASSWORD HERE]
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server TACACS+ (inside) host [ENTER TACACS+ SERVER IP ADDRESS HERE] [ENTER SECRET KEY HERE] timeout 10
aaa authentication http console TACACS+ LOCAL
aaa authentication ssh console TACACS+ LOCAL
aaa authentication telnet console TACACS+ LOCAL
aaa authentication enable console TACACS+ LOCAL
aaa authorization command TACACS+ LOCAL
aaa accounting enable console TACACS+
aaa accounting ssh console TACACS+
Correct Answer by Julio Carvajal about 3 years 7 months ago
Glad to know that I could help (Remember to mark the question as answered as that was the main topic of this ticket)
Now, moving to the new issue.
This basically tells the ASA use the local usermane and password database not the enable password.
If you want to authenticate using the locally configured enabled password just remove
And you will be always authenticating using the locally configured password.
This is different than from an IOS device that provides the option to use the enable database on the router itself when authenticating~
Looking for some Networking Assistance?
Contact me directly at [email protected]
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
HeyRizwan,
What ACS version are you running??
Make sure you defined the username with a static privilege level of 15 otherwise it will not be able to pass the enable authentication.
If ACS 5.x or higher go to the policy elements: Shell Profile and make sure you have one assigned for a static maximum privilege of 15 and most important that its applied into a access-policy rule
Cheers,
Overall Rating: 5 (2 ratings)
Collin Clark Mon, 01/06/2014 - 14:15
  • Purple, 4500 points or more
What does the CLI return after you enter the password foe enable mode? What does it say in logs on the TACACS server?
Correct Answer
Julio Carvajal Mon, 01/06/2014 - 17:04
HeyRizwan,
Cheers,
rizwan555 Fri, 01/10/2014 - 08:36
Thanks for assistance. Issue of login to enable-mode via tacacs+ credential is resolved as per your advice as I have found that as soon I configure ACS User Setup-> Advanced TACACS+ Settings-> Max Privilege for any AAA Client->15 instead of “Use Group Level Setting”(which is privilege 15 anyway) then I can login to the firewall enable-mode via tacacs+, successfully.
Now problem is that if I turn off the ACS, then I can successfully login to the firewall user-mode via fallback local-credentials of below username/ password, but I can only login to the enable-mode via password:user123, I am unable to login to the enable-mode via enable-password i.e password2
Configurations:
username user1 password user123 privilege 15
enable password password2
aaa-server TACACS+ (inside) host 10.10.10.10
key abc123
Problem:
Test-ASA> en
Password: password2
Password:
Password: user123
Test-ASA#
Correct Answer
Julio Carvajal Fri, 01/10/2014 - 08:52
Cheers,
rizwan555 Wed, 02/05/2014 - 06:33
I thought I keep the Discussion in same page as it’s very much related to it.
Please advise that timers I have added below are in Cisco best practices or not. Also what the function of below commands, do you recommend me to add it or not.
reactivation-mode timed
~~~~~~~~~~~Please advise timers in below aaa commands~~~~~~~~~~~~~~~~~~~~
timeout 6
key abc123
aaa-server TACACS+ (inside) host 10.10.20.10
timeout 6
key abc123
sreeharsha.kamisetty Thu, 11/17/2016 - 06:34
Hello Rizwan,
thanks for the post, i had a similar situation but tried all the possible solutions. your post was giving me some hope to resolve this issue but not able to find the exact settings on ACS as per your navigation. can you please let me know the version of ACS you figured it out?
Sreeharsha
Related Content
