Cisco 3702e versus 3702p - what is different?
Jan 7th, 2014
Does anybody have a link to a list of differences between 3702e and 3702p? Looks like 3702p is suggested for dense deployment but what does that actually mean?
Overall Rating: 4.9 (6 ratings)
Scott Fella Tue, 01/07/2014 - 09:47
The "P" access points like the 3502p also is made for stadium , convention center (very high ceiling), and or arena type environments.  We have never used a "p" AP other than stadiums so far.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
vlad.mihailov Wed, 01/08/2014 - 16:57
But what is the actuall difference? Ie narrow beamforming, more clients supported, can use colla to clean the poprorn off the plate - is there anything measurable?
Scott Fella Wed, 01/08/2014 - 18:37
Antennas. There is one specific antenna made for the 'P'.
Arun Greig John Sun, 01/26/2014 - 23:54
Scott,
Can you please specify the partnumber of the antenna made for P series?
I am also trying to find the appropriate antenna for 3702P...
Arun
Sandeep Choudhary Mon, 01/27/2014 - 02:11
HI Arun,
The 3700p is stadium only and require the stadium antenna and I don't  see that listed yet. Take a look at the 3500p as those are also stadium  and uses only the stadium antennas.
Check here:
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
Also check this:
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/at_a_glance_c45-513837.pdf
Dont forget to rate helpful posts
Scott Fella Mon, 01/27/2014 - 21:58
Just remember that there is a place for the 3702p... Really for stadium, arenas and very high density areas. The 3702i and 3702e's should be used in all other locations.
