Warning message
two group of 2960-s stacked switches connection problem
Answered Question
Jan 7th, 2014
I have two group of 2960 stacked switches connected by trunked (UTP) interface
stack-1                       stack-2
SW-1 -------UTP-------- SW-A
SW-2                           SW-B
SW-3                           SW-C
SW-4                           SW-D
I cannot ping stacks by their management IP?
Here is the config of stack-1
stack-1#sh switch
Switch/Stack Mac Address : c025.5cf1.0b80
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master c025.5cf1.0b80     14     1       Ready
2       Member 64e9.5055.bd00     1      1       Ready
3       Member 64e9.501d.f980     1      1       Ready
4       Member 64e9.5062.1580     1      1       Ready
stack-1#sh switch stack-ports
  Switch #    Port 1       Port 2
    1           Ok           Ok
    2           Ok           Ok
    3           Ok           Ok
    4           Ok           Ok
stack-1#sh run
switch 1 provision ws-c2960s-48lps-l
switch 2 provision ws-c2960s-48ts-l
switch 3 provision ws-c2960s-48ts-l
switch 4 provision ws-c2960s-48ts-l
spanning-tree mode pvst
interface GigabitEthernet1/0/48
description uplink_other_stack
switchport trunk allowed vlan 1,200,379,380,396-399
switchport mode trunk
interface Vlan1
no ip address
interface Vlan200
description management
ip address 10.8.15.4 255.255.0.0
Correct Answer by Leo Laohoo about 3 years 7 months ago
Ok, try these sequence of commands from switch stack 1 ...
conf t
cluster enable
do sh cluster candidate
!!!!  Note the MAC address of stack-2
cluster member mac pass
end
rc 1
!!!! If everything is correct, you should be able to remote into stack-2.
Overall Rating: 5 (1 ratings)
Leo Laohoo Tue, 01/07/2014 - 13:56
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Can you post the output to commands of both stacks:
1.  sh interface trunk;
2.  sh int vlan 200;
recep.sefer Tue, 01/07/2014 - 22:39
stack-1#sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi1/0/48    on               802.1q         trunking      1
Gi1/0/49    on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi1/0/48    1,200,379-380,396-399
Gi1/0/49    1,200,379-380,396-399
Port        Vlans allowed and active in management domain
Gi1/0/48    1,200
Gi1/0/49    1,200
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/48    1,200
Gi1/0/49    1,200
sack-1#sh int vlan 200
Vlan200 is up, line protocol is up
  Hardware is EtherSVI, address is c025.5cf1.0bc1 (bia c025.5cf1.0bc1)
  Description: management
  Internet address is 10.8.15.4/16
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1000 bits/sec, 3 packets/sec
     112256 packets input, 7333704 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     961 packets output, 95330 bytes, 0 underruns
     0 output errors, 2 interface resets
recep.sefer Tue, 01/07/2014 - 23:12
Here is sh cdp neigbors
stack-1#sh cdp neighbors det
Device ID: BACKBONE
Entry address(es):
  IP address: 10.15.20.1
Platform: cisco WS-C4506-E,  Capabilities: Router Switch IGMP
Interface: GigabitEthernet1/0/49,  Port ID (outgoing port): GigabitEthernet4/1
Holdtime : 146 sec
Version :
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 15.1(2)SG, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 05-Dec-12 05:58 by prod_rel_team
advertisement version: 2
VTP Management Domain: ''
Native VLAN: 1
Duplex: full
Management address(es):
Device ID: stack-2
Entry address(es):
Platform: cisco WS-C2960S-48TS-L,  Capabilities: Switch IGMP
Interface: GigabitEthernet1/0/48,  Port ID (outgoing port): GigabitEthernet1/0/48
Holdtime : 144 sec
Version :
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 28-Jan-13 10:28 by prod_rel_team
Protocol Hello:  OUI=0x00000C, Protocol ID=0x0112; payload len=27, value=00000000FFFFFFFF010221FF00000000000064E950825200FF0000
Native VLAN: 1
Duplex: full
Leo Laohoo Tue, 01/07/2014 - 23:21
  • Hall of Fame,
    2017 LAN, Wireless
That's why you can't ping the 2nd stack's managmenet IP address.  You can't see it in "sh cdp n".
Provide the following commands from the 2nd stack:
1.  sh interface vlan 200;
2.  sh interface trunk
Maybe interface VLAN 200 is in "shutdown".
Leo Laohoo Tue, 01/07/2014 - 22:43
  • Hall of Fame,
    2017 LAN, Wireless
Are ports G1/0/48 and G1/0/49 going to the same switch?
recep.sefer Tue, 01/07/2014 - 23:52
Yes they are on same switch (stack-1)
here is teh topology
I can reach stack-1 by VLAN200 IP adress
But I cannot reach stack-2
                                       stack-1                       stack-2
Backbone------fiber-------SW-1 -------UTP-------- SW-A
                                       SW-2                           SW-B
                                       SW-3                           SW-C
                                       SW-4                           SW-D
Leo Laohoo Wed, 01/08/2014 - 00:07
  • Hall of Fame,
    2017 LAN, Wireless
On the stack 2, post the output to the following commands:
1.  sh interface trunk; and
2.  sh interface vlan 200
recep.sefer Wed, 01/08/2014 - 00:49
I cannot reach (telnet) stack-2
It is so far to me
I am sure stack-2 config is same as stack-1
is it possible to solve it without going to stack-2
Leo Laohoo Wed, 01/08/2014 - 01:09
  • Hall of Fame,
    2017 LAN, Wireless
Is VLAN 1 on both stack enabled or disabled?
recep.sefer Wed, 01/08/2014 - 02:00
Yes
Vlan 1 is enabled
here is config
interface Vlan1
no ip address
interface Vlan200
ip address ...
stack-1#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/4, Gi1/0/5, Gi1/0/6 ....
Correct Answer
Leo Laohoo Wed, 01/08/2014 - 02:03
  • Hall of Fame,
    2017 LAN, Wireless
conf t
cluster enable
end
rc 1
recep.sefer Wed, 01/08/2014 - 03:30
Thank you very much
I  access switch with you help
I correct th config
and everthing works
Leo Laohoo Wed, 01/08/2014 - 13:37
  • Hall of Fame,
    2017 LAN, Wireless
Thank you very much for taking the time to rate our posts.
