WCCP on IPSEC Tunnel
Jan 7th, 2014
     How much ipsec tunnel to support WCCP?
     My client have one asr 1002 ,the device have many ipsec tunnel ,more than 2000.
     Can WCCP support all the ipsec tunnel ? or have quantitative restrictions
like this config:
     int tunnel 100
     ip wccp 61 redirect in
     int tunnel 101
     int tunnel 10x
     int tunnel 2000
     ip wccp 61 rediect in
Gurpreet Kochar Thu, 01/09/2014 - 05:54
You are likely to run into TCAM issues.
Instead of applying redirect in on multiple ingress interfaces, may be you could consider applying wccp on the common egress interfaces ( ip wccp 61 redirect out ).
------LAN-----ASR--Multiple tunnel interfaces------ WAN --------
Instead of configuring
int tunnel 100
     int tunnel 101
     int tunnel 10x
      int tunnel 2000
you could probably configure
interface
ip wccp 62 redirect in
interface
ip wccp redirect exclude in
Gurpreet Kochar
