Warning message
UDLD in cisco router
Jan 8th, 2014
Hi all,
Do we have udld support in routers ? can someone pls guide me if we have this feature available on cisco routers ?
Overall Rating: 5 (1 ratings)
Leo Laohoo Wed, 01/08/2014 - 01:24
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I don't think UDLD is supported in routers.
M. G. Wed, 01/08/2014 - 02:50
UDLD is used to prevent STP loops, therefore it L2 protocol and it does not run on the L3 interfaces. If you have router with a switch ports on the router, then you might have it
Collin Clark Wed, 01/08/2014 - 09:17
  • Purple, 4500 points or more
UDLD is a Layer 2 protocol that enables devices connected through fiber-optic or twisted-pair Ethernet cables to monitor the physical configuration of the cables and detect when a unidirectional link exists. It is not used to prevent STP loops. It is supported on some of the etherswitch daughter cards. I don't have any fiber terminating on the chassis SFP ports so I'm not sure if it's supported there.
M. G. Wed, 01/08/2014 - 20:36
This document explains how the Unidirectional Link Detection (UDLD) protocol can help to prevent forwarding loops and blackholing of traffic in switched networks.
Cisco
Bhishma Khanna Wed, 01/08/2014 - 13:05
  • Cisco Employee,
Hi Jonn,
Just to give some more information about UDLD, whenever the switch detects a unidirectional link in the layer 2 LAN switching environment, it prefers to block the port completly(send it to err-disabled) rather than allowing the unidirectional flow of information. It has no use in the layer 3 environment.
Thanks.
