LC to LC Connector ATEX/IECx Certified
Jan 8th, 2014
  First post guys so please be patient if I mess up.
I need a solution to connect 2 LC patch leads within an Exe enclosure.
One lead comes from a Westermo MCI-211G media convertor fitted with a Cisco GLC-SX-MM SFP transceiver, which is located within an Exd enclosure (then potted through into the Exe enclosure as per NORSOK regs), the other patch lead then goes to a non Ex rated patch panel (the media convertor is powered from the safe power system post purge).
If I wasn't constrained by the design of this particular module I would use an ATEX approved media converter (Primation P-Ex 1000 series) and locate it outside the enclosures but .....
I know that a standard LC to LC connector is a "simple device" and is completely passive, however it is not stamped with the magic ATEX CE approval.
Any solutions very welcome.
Andy
Leo Laohoo Thu, 01/09/2014 - 04:18
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Won't make any difference. The main thing is your LC-LC patch cable should be, at least, OM3.
Sent from Cisco Technical Support Wii App
andrewsmith4 Thu, 01/09/2014 - 04:45
Leo,
Please qualify "won't make any difference"
If the connector is not ATEX or IECEx approved it cannot be used in a potentially explosive area (Exe enclosure)
Any one out there who has connected LC ended patch leads within an explosive area without using a powered switch?
