Warning message
Second call waiting notification on cisco ip phone where an agent is logged in and talking to a customer in ucce
Jan 8th, 2014
I have been facing a issue, where an agent is already busy talking to a customer and another incoming call notification is displayed on the screen. I am in a UCCE enviroment where single line is configured with directory number. ICM should not direct the call to an agent who is already on a call.
UCCE Version 8.5.2
CTI Version 8.5.2
CUCM version 8.5.2
Gergely Szabo Wed, 01/08/2014 - 08:15
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
Hi, this sounds like a "split brain" problem.
Did you check the communication between ICM Side A and B? Do you see any errors?
G.
Dinesh Rathi Wed, 01/08/2014 - 08:22
Communication seems to be fine between Side A and B. Also I have found that the RouterCallKey value for this type of calls is 0.
Gergely Szabo Wed, 01/08/2014 - 08:25
Oh, then it must be an incoming call from within the enterprise, not routed by ICM. Probably an internal call.
Can you check the agent phones and if necessary, set the Busy Trigger to 1.
G.
Dinesh Rathi Wed, 01/08/2014 - 08:52
I have checked and found that it is not an internal call. Busy trigger for all the phones in the sytem has been set to 2 however as I mentioned, only 1 directory number has been configured on the phone and everything was working fine till now. I have started facing this issue since two days. No major changes has been made in the system.
david.macias Wed, 01/08/2014 - 10:31
  • Blue, 1500 points or more
So you've confirmed that the 2nd call is an ICM call?  Do you have logs showing this?
david
1977bjorn Thu, 01/09/2014 - 07:02
You say that the busy trigger is set to 2... change it to 1 instead.
Related Content
