Warning message
IPSEC duplicated entry when listing cripto sessions
Jan 8th, 2014
Very weird:
My crypto session with ZZZ.ZZZ.ZZZ.ZZZ. apears three times ....
mdz-gc-he-asr#show crypto session brief
Status: A- Active, U - Up, D - Down, I - Idle, S - Standby, N - Negotiating
        K - No IKE
ivrf = (none)
           Peer     I/F        Username          Group/Phase1_id   Uptime Status
  XXX.XXX.XXX.XXX Gi0/1/1                   XXX.XXX.XXX.XXX. 00:45:08    UA
  ZZZ.ZZZ.ZZZ.ZZZ. Gi0/1/1                            ZZZ.ZZZ.ZZZ.ZZZ.             UI
  ZZZ.ZZZ.ZZZ.ZZZ  Gi0/1/1                                                      UI
    YYY.YYY.YYY.YYY    Tu20                              YYY.YYY.YYY.YYY     7w0d    UA
Though I have my session up , I can not course traffic through the tunnel,
How can I restart my session with peer zzz.zzz.zzz.zzz ?
Any ideas ?
Leandro.
Jouni Forss Wed, 01/08/2014 - 12:08
To my understanding you can clear the session with
clear crypto session remote
You could probably also use command
clear crypto isakmp
Before that you would check the output of
show crypto isakmp sa
- Jouni
leandro roggerone Tue, 01/21/2014 - 04:45
O figured out , the problem was a duplicated entry in the ACLs that each match statement was refering on the crypto maps.
crypto map CRYPTO 10 ipsec-isakmp
description "site to site 1"
set peer XX.XX.XX.XX
set transform-set trans1
match address 150
crypto map CRYPTO 30 ipsec-isakmp
description "site to site 2"
set peer YY.YY.YY.YY
set transform-set trans2
match address 180
access-list 150 permit ip host 172.24.3.5 host 172.22.83.149  ##### had to delete and works!
access-list 180 permit ip host 172.24.3.5 host 172.22.83.149
