ip virtual-reassembly and ZBF
Ruterford
I am wondering if this is necessary to enable ip virtual-reassembly on the internet facing interface on a VPN router(DMVPN spoke)  in case if I don't have any NAT configured on it. I run ZBF and have only policy that allows only VPN traffic for DMVPN spoke, DHCP and management via SSH from some specific host only . I am reluctant to enable it, need expert's comment.
Here is my configuration below, so all far works fine:
interface FastEthernet4
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
zone-member security outside
ip tcp adjust-mss 1360
duplex auto
speed auto
no cdp enable
end
ip access-list extended ISAKMP_IPSEC_DHCP_in
permit udp any any eq bootpc
permit esp host <PUBLIC IP OF DMVPN HUB> any
permit udp host <PUBLIC IP OF DMVPN HUB> eq isakmp any eq isakmp
permit udp host <PUBLIC IP OF DMVPN HUB> eq non500-isakmp any eq non500-isakmp
ip access-list extended ISAKMP_IPSEC_DHCP_out
permit udp any any eq bootps
permit esp any host <PUBLIC IP OF DMVPN HUB>
permit udp any eq isakmp host <PUBLIC IP OF DMVPN HUB> eq isakmp
permit udp any eq non500-isakmp host <PUBLIC IP OF DMVPN HUB> eq non500-isakmp
ip access-list extended SSHaccess
permit tcp host <MGMT HOST> any eq 22
class-map type inspect match-all IPSEC-DHCP-IN-cmap
match access-group name ISAKMP_IPSEC_DHCP_in
class-map type inspect match-all SSHaccess-cmap
match access-group name SSHaccess
policy-map type inspect Outside-Router-pmap
class type inspect SSHaccess-cmap
  inspect
class type inspect IPSEC-DHCP-IN-cmap
  pass
class class-default
  drop log
class-map type inspect match-all IPSEC-DHCP-OUT-cmap
match access-group name ISAKMP_IPSEC_DHCP_out
policy-map type inspect Router-Outside-pmap
class type inspect IPSEC-DHCP-OUT-cmap
  pass
class class-default
  drop log
policy-map type inspect Inside-Outside-pmap
class class-default
  drop log
policy-map type inspect Outside-Inside-pmap
class class-default
  drop log
policy-map type inspect Outside-Outside-pmap
class class-default
  drop log
zone-pair security outside-to-router source outside destination self
service-policy type inspect Outside-Router-pmap
zone-pair security router-to-outside source self destination outside
service-policy type inspect Router-Outside-pmap
zone-pair security inside-to-outside source inside destination outside
service-policy type inspect Inside-Outside-pmap
zone-pair security outside-to-inside source outside destination inside
service-policy type inspect Outside-Inside-pmap
zone-pair security outside-to-outside source outside destination outside
service-policy type inspect Outside-Outside-pmap
2 Accepted Solutions
Marcin Latosiewicz
No virtual-reassembly it not required for anything-VPN.
It's only needed for features which might want to have a look at full packets (NAT is one, certain inspection engines as other).
Vide:
http://www.cisco.com/en/US/docs/ios-xml/ios/security/d1/sec-cr-i3.html#wp3273051086
Hello Ruteford,
No, no need for this.
Just make sure you configure your ZBFW as restrictive as possible using the self-zone to protect the router and make sure you log everything to determine any kind of problems
Looking for some Networking Assistance?
Contact me directly at jcarvaja@laguiadelnetworking.com
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
5 Replies 5
Marcin Latosiewicz
Vide:
Julio Carvajal
Hello Ruterford,
As Marcin said not related to that.
Now let's talk about the usage of that feature:
It would basically let you configure the router to react to fragmentation attacks where you will deterine how much fragments a packet can have or the maximum amount of IP packets that can be using the reasembly feature at the same time, the time you have to reassemble an IP packet.
So based on how the network behaves, the traffic you receive you can make a desicion about to enable it or not/
Cheers,
Julio Carvajal
Thanks for explanations guys!
So the only traffic I receive on the poublic interface(via internet thru ISP) here on this VPN router is
1) VPN related (ESP/ISAKMP/NON-500 ISAKMP)
2) SSH (being allowed on public interface only from some certain host for out of band management to self zone)
3) DHCP client (being allowed on public interface from any to self zone)
4) No NAT enabled at all - internal hosts can talk to networks advertised from VPN tunnel interfaces
Based on that - what would your advise be - do I need to bother enabling ip virtual-reassembly on public interface or not?
bump
Hello Ruteford,
Cheers,
Julio Carvajal
