Five-Member 2960X Stack with 0.5-Meter Cables
Answered Question
Jan 8th, 2014
Hi can anyone help me with the proper way to connect a 3 and 5 member of 2960X stack, cause i just read the installation guide but only come the way to four member and i cant fine the logic to connnect 3 and 5 members.
Regards!!!
Correct Answer by Bhishma Khanna about 3 years 7 months ago
For graphical view of the connections please click on the below link:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12995/white_paper_c11-728327.html
Search by :
Deployment Topologies
You would get the 3 stack connection topology.
By connecting in full rebundancy, you would get 40 Gbps bandwidth per member in 2960-X stack.
Correct Answer by M. G. about 3 years 7 months ago
Hi, you can try something like this
1-2
1-3
2-1
2-4
3-1
3-5
4-5
4-2
5-4
5-3
Hope this helps
Overall Rating: 5 (3 ratings)
Correct Answer
M. G. Wed, 01/08/2014 - 20:48
1-2
1-3
2-1
2-4
3-1
3-5
4-5
4-2
5-4
5-3
Hope this helps
FERNANDO FERNAN... Wed, 01/08/2014 - 21:08
Hi Mate, thanks for me help me, im a little confuse withe the logic on the pattern that u send to me i im going to try to explain hope that im ok:
SW 1 port 1 - SW 2 port 1
SW 1 port 2 - SW 3 port 1
SW 2 port 1 - SW 1 port 1
SW 2 port 2 - SW 4 port 1
SW 3 port 1 - SW 1 port 2
SW 3 port 2 - SW 5 port 1
SW 4 port 1 - SW 2 port 2
SW 4 port 2 - SW 5 port 2
SW 5 port 1 - SW 3 port 2
SW 5 port 2 - SW 4 port 2
Regards!
M. G. Wed, 01/08/2014 - 21:32
yup, that was my idea, in a simplified way . Hopefully it helps.
Mate
Correct Answer
Bhishma Khanna Wed, 01/08/2014 - 23:17
  • Cisco Employee,
Search by :
bberry Fri, 03/07/2014 - 07:21
Hi all,
Ok so why not always go ...
     Switch 1 port 2 to Switch 2 port 1
     Switch 2 port 2 to Switch 3 port 1
     Last switch port 1 to Switch 1 port 1
It looks like depending on number of switches in stack there is a different pattern? Just askign as I am looking to going to a 2960X stack from a Distribution / Access configuration.
Brent
