Manager-Assistant setup visual/audio alert turn on/off for manager
Jan 9th, 2014
Hi Expert,
I would need some help if any of you has bumped into this before or has any idea:
I have a Manager-Assistant setup (CUCM 8.6):
- shared line solution
- 2 managers with 1 assistant
Call comes in to manager main number: it rings on assistant phone and have visual info on manager phone.
In case assistant is away from the desk, so can not take calls
Is it possible to turn audio alerting also on for the manager phone (by assistant)?
and when assistant is back turn this off again, so only visual info will be seen on manager phone.
Thanks for any idea!
Tibor
Hermanus Janse ... Thu, 01/09/2014 - 23:12
  • Silver, 250 points or more
Have you tried making your assistant go offline first on the assistant application and see if the call rings thru to the manager then?
Also on the managers application you can set an Audio Alert on or of in Proxy-Line mode.
See the following doc as well:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucma/3_3_2/english/user/guide/IPMAovr.pdf
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/3_3_2/ccmfeat/fsipma.pdf
