01-09-2014 04:46 PM - edited 03-16-2019 09:11 PM
Can someone tell me if there is anything special to adding the 8831 SIP phone to the callmanager? I've only configured skinny phones in the past. Is the setup the same?
Shane
01-09-2014 05:34 PM
Yes, pretty much the same thing
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
01-09-2014 06:02 PM
Thank you.
