Warning message
Help with ACS 5.4 and RSA SecurID Server!!
Jan 10th, 2014
Hi all,
I have run into some issues when trying to authenticate wireless users against an RSA SecurID server and would appreciate any input from the community.
The RSA server configuration has been verified as correct, and the only real log as such (authentication monitor) shows:
User “me” attempted to authenticate using authenticator “SecurID_Native”. The user belongs to security domain “SystemDomain”. Not very helpful.
The ACS AAA log shows the following:
Jan 10,14 3:43:30.353 PM Radius authentication failed for USER: me  MAC: 00-19-7e-88-5a-7b  AUTHTYPE: EAP-FAST(EAP-GTC) Radius authentication failed.
Detailed log:
Authentication Details
Logged At: January 10,2014 3:43:30.353 PM
ACS Time: January 10,2014 3:43:30.343 PM
ACS Instance: wlan-acs-1
Authentication Method: PAP_ASCII
EAP Authentication Method : EAP-GTC
EAP Tunnel Method : EAP-FAST
User
ACS Username: me
RADIUS Username :
Calling Station ID: 00-19-7e-88-5a-7b
Framed IP Address:
Host Lookup:
Network Device
Network Device: wlc-02
Network Device Groups: Device Type:All Device Types:5508
NAS IP Address: 10.201.30.129
NAS Identifier:
NAS Port:
NAS Port ID: 13
NAS Port Type:
Access Policy
Access Service: Default Network Access
Identity Store: rsaserver
Authorization Profiles:
Exception Authorization Profiles:
Active Directory Domain:
Identity Group:
Access Service Selection Matched Rule: Rule-1
Identity Policy Matched Rule: Default
Selected Identity Stores: rsaserver
Query Identity Stores:
Selected Query Identity Stores:
Group Mapping Policy Matched Rule:
Authorization Policy Matched Rule:
Authorization Exception Policy Matched Rule:
CTS
CTS Security Group:
Other
ACS Session ID: wlan-acs-1/178729561/86
Audit Session ID:
Tunnel Details:
H323 Attributes:
SSG Attributes:
Cisco-AVPairs:
Other Attributes: ACSVersion=acs-5.4.0.46-B.221
ConfigVersionId=26
If further information is needed, please let me know.
Thanks for your time.
nix-patheon Wed, 01/15/2014 - 04:55
For anyone having the same issue, I found that removing the configuration from the RSA Token Server external identity store and configuring for RADIUS Identity Server solved my problem.
Trending Topics - Security & Network
