Cisco 1800 VPN
Jan 12th, 2014
I am trying to create an ipsec vpn to Amazon VPC for the first time but I can't get it to work. Debug crypto isaksmp shows the following;
*Jan 13 05:17:52.915: ISAKMP:(0):No pre-shared key with x.x.x.x
*Jan 13 05:17:52.915: ISAKMP:(0):Preshared authentication offered but does not match policy!
*Jan 13 05:17:52.919: ISAKMP:(0):Encryption algorithm offered does not match policy
*Jan 13 05:17:52.919: ISAKMP:(0):deleting SA reason "Phase1 SA policy proposal not accepted" state (R) MM_NO_STATE (peer x.x.x.x)
But I've checked the config and it looks right. Can anyone shed some light on it for me please?
Jon Marshall Mon, 01/13/2014 - 09:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Chris
It looks like the phase 1 policies are not matching. Each device will run through all the phase 1 policies until it either finds a match or runs out of policies.
That's about all that can be said from what you have posted. What settings did they send you for phase 1 ?
Perhaps you can post the settings they sent plus your router config. I'm assuming you have set the pre-shared key and that it matches the one they sent.
Don't post the key in plaintext on this forum.
Jon
chrisgerke Mon, 01/13/2014 - 14:10
The config for the 1800 is...I simply copied the settings from the wizard provided by the Amazon VPC setup. However there was one line in it that will not apply to my router.
track 100 ip sla 100 reachability
Current configuration : 3741 bytes
version 12.4
service password-encryption
hostname xxxxxxxxxxxxxxxxxxxxxxxxxx
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool LAN
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server xxxxxxxxxxxxxxxxxxxxxxxxxx
   lease 5
ip name-server xxxxxxxxxxxxxxxxxxxxxxxxxx
ip sla 100
icmp-echo 169.254.247.17 source-interface Tunnel1
timeout 1000
frequency 5
ip sla schedule 100 life forever start-time now
ip sla 200
icmp-echo 169.254.247.21 source-interface Tunnel2
timeout 1000
frequency 5
ip sla schedule 200 life forever start-time now
crypto keyring keyring-vpn-amazon_vpc_1
  local-address MY_ADSL_EXTERNAL_STATIC_IP
  pre-shared-key address AMAZON_PROVIDED_PEER_1 key xxxxxxxxxxxxxxxxxxxxxxxxxx
crypto keyring keyring-vpn-amazon_vpc_2
  pre-shared-key address AMAZON_PROVIDED_PEER_2 key xxxxxxxxxxxxxxxxxxxxxxxxxx
crypto isakmp policy 200
encr aes
authentication pre-share
group 2
lifetime 28800
crypto isakmp policy 201
encr aes
group 2
lifetime 28800
crypto isakmp keepalive 10 10
crypto isakmp profile isakmp-vpn-amazon_vpc_1
   match identity address AMAZON_PROVIDED_PEER_1 255.255.255.255
crypto isakmp profile isakmp-vpn-amazon_vpc_2
   match identity address AMAZON_PROVIDED_PEER_2 255.255.255.255
crypto ipsec security-association replay window-size 128
crypto ipsec transform-set ipsec-prop-vpn-amazon_vpc_1 esp-aes esp-sha-hmac
crypto ipsec transform-set ipsec-prop-vpn-amazon_vpc_2 esp-aes esp-sha-hmac
crypto ipsec df-bit clear
crypto ipsec profile ipsec-vpn-amazon_vpc_1
set transform-set ipsec-prop-vpn-amazon_vpc_1
set pfs group2
crypto ipsec profile ipsec-vpn-amazon_vpc_2
set transform-set ipsec-prop-vpn-amazon_vpc_2
set pfs group2
interface Tunnel1
ip address 169.254.247.18 255.255.255.252
ip virtual-reassembly
ip tcp adjust-mss 1387
tunnel source MY_ADSL_EXTERNAL_STATIC_IP
tunnel destination AMAZON_PROVIDED_PEER_1
tunnel mode ipsec ipv4
tunnel protection ipsec profile ipsec-vpn-amazon_vpc_1
interface Tunnel2
ip address 169.254.247.22 255.255.255.252
tunnel destination AMAZON_PROVIDED_PEER_2
tunnel protection ipsec profile ipsec-vpn-amazon_vpc_2
interface FastEthernet0
description ISP
ip address 192.168.1.26 255.255.255.0
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
switchport access vlan 13
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
interface Vlan13
ip address 10.10.10.1 255.255.255.0
interface Async1
no ip address
encapsulation slip
router eigrp 1
no auto-summary
ip route 10.0.0.0 255.255.0.0 Tunnel1 track 100
ip route 10.0.0.0 255.255.0.0 Tunnel2 track 200
ip route 0.0.0.0 0.0.0.0 192.168.1.1
control-plane
webvpn context Default_context
ssl authenticate verify all
no inservice
auVPC01 con0 is now available
Press RETURN to get started.
Jon Marshall Mon, 01/13/2014 - 14:29
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Chris
Is there meant to be a link or diagram in the last bit of your post ?
Jon
Jon Marshall Mon, 01/13/2014 - 14:46
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Chris
Not sure what to tell you then. Can you try removing the key and retyping it in as i have made that sort of mistake myself before.
Also can you post all of the configuration settings for the other end.
Jon
chrisgerke Mon, 01/13/2014 - 14:55
Unfortunately I already tried that and it didn't help. The following are the settings from the other end (note though I do not have direct console access), the other end is Amazon VPC. The following is the txt file that the VPC wizard produces.
The only thing i can think is that the port forwarding on my asdl modem to the cisco 1800 isn't setup correctly or isn't working. Maybe I need to put that modem in bridged mode and set the ISP external ip an the 1800 interface.
! Amazon Web Services
! Virtual Private Cloud
! AWS utilizes unique identifiers to manipulate the configuration of
! a VPN Connection. Each VPN Connection is assigned an identifier and is
! associated with two other identifiers, namely the
! Customer Gateway Identifier and Virtual Private Gateway Identifier.
! Your VPN Connection ID                       : xxxxxxxxxxxxxxxxxxxxxxxxxx
! Your Virtual Private Gateway ID         : xxxxxxxxxxxxxxxxxxxxxxxxxx
! Your Customer Gateway ID                      : xxxxxxxxxxxxxxxxxxxxxxxxxx
! This configuration consists of two tunnels. Both tunnels must be
! configured on your Customer Gateway.
! IPSec Tunnel #1
! #1: Internet Key Exchange (IKE) Configuration
! A policy is established for the supported ISAKMP encryption,
! authentication, Diffie-Hellman, lifetime, and key parameters.
! Note that there are a global list of ISAKMP policies, each identified by
! sequence number. This policy is defined as #200, which may conflict with
! an existing policy using the same number. If so, we recommend changing
! the sequence number to avoid conflicts.
  encryption aes 128
  group 2
  lifetime 28800
  hash sha
exit
! The ISAKMP keyring stores the Pre Shared Key used to authenticate the
! tunnel endpoints.
exit
! An ISAKMP profile is used to associate the keyring with the particular
! endpoint.
exit
! #2: IPSec Configuration
! The IPSec transform set defines the encryption, authentication, and IPSec
! mode parameters.
crypto ipsec transform-set ipsec-prop-vpn-amazon_vpc_1 esp-aes 128 esp-sha-hmac
  mode tunnel
exit
! The IPSec profile references the IPSec transform set and further defines
! the Diffie-Hellman group and security association lifetime.
  set pfs group2
  set security-association lifetime seconds 3600
exit
! Additional parameters of the IPSec configuration are set here. Note that
! these parameters are global and therefore impact other IPSec
! associations.
! This option instructs the router to clear the "Don't Fragment"
! bit from packets that carry this bit and yet must be fragmented, enabling
! them to be fragmented.
! This option enables IPSec Dead Peer Detection, which causes periodic
! messages to be sent to ensure a Security Association remains operational.
crypto isakmp keepalive 10 10 on-demand
! This configures the gateway's window for accepting out of order
! IPSec packets. A larger window can be helpful if too many packets
! are dropped due to reordering while in transit between gateways.
! This option instructs the router to fragment the unencrypted packets
! (prior to encryption).
crypto ipsec fragmentation before-encryption
! #3: Tunnel Interface Configuration
! A tunnel interface is configured to be the logical interface associated
! with the tunnel. All traffic routed to the tunnel interface will be
! encrypted and transmitted to the VPC. Similarly, traffic from the VPC
! will be logically received on this interface.
! Association with the IPSec security association is done through the
! "tunnel protection" command.
! The address of the interface is configured with the setup for your
! Customer Gateway.  If the address changes, the Customer Gateway and VPN
! Connection must be recreated with Amazon VPC.
interface Tunnel1
  ! This option causes the router to reduce the Maximum Segment Size of
  ! TCP packets to prevent packet fragmentation.
  no shutdown
exit
! #4 Static Route Configuration
! Your Customer Gateway needs to set a static route for the prefix corresponding to your
! VPC to send traffic over the tunnel interface.
! An example for a VPC with the prefix 10.0.0.0/16 is provided below:
! ip route 10.0.0.0 255.255.0.0 Tunnel1 track 100
! SLA Monitor is used to provide a failover between the two tunnels. If the primary tunnel fails, the redundant tunnel will automatically be used
! This sla is defined as #100, which may conflict with an existing sla using same number.
! If so, we recommend changing the sequence number to avoid conflicts.
ip sla 100
   timeout 1000
   frequency 5
exit
! IPSec Tunnel #2
! sequence number. This policy is defined as #201, which may conflict with
  encryption aes 128
  group 2
  lifetime 28800
  hash sha
exit
! tunnel endpoints.
exit
! endpoint.
exit
! mode parameters.
crypto ipsec transform-set ipsec-prop-vpn-amazon_vpc_2 esp-aes 128 esp-sha-hmac
  mode tunnel
exit
  set pfs group2
exit
! associations.
interface Tunnel2
  no shutdown
exit
! ip route 10.0.0.0 255.255.0.0 Tunnel2 track 200
! This sla is defined as #200, which may conflict with an existing sla using same number.
ip sla 200
   timeout 1000
   frequency 5
exit
track 200 ip sla 200 reachability
! Additional Notes and Questions
!  - Amazon Virtual Private Cloud Getting Started Guide:
!       http://docs.amazonwebservices.com/AmazonVPC/latest/GettingStartedGuide
!  - Amazon Virtual Private Cloud Network Administrator Guide:
!       http://docs.amazonwebservices.com/AmazonVPC/latest/NetworkAdminGuide
