Is there a command to show current invert txclock setting?
JUSTASKING
CISCO 2600/2800/2900 series routers with HWIC-2T/HWIC-4T. We have enabled invert txclock on a serial port, however it does not reflect that setting under show interface command. Is there alternate command that will reflect how the invert option is currenlty set?
JUSTASKING
I found the answer.  Sho run int x/x/x
