Warning message
CRS-1 boot failed problem
Jan 13th, 2014
Hi expert
after greeting ,
I  have CRS1/8 with  two RPs installed, suddenly  RP0 failed to boot and standby RP1  is running as active RP, when i console to RP0  i got the following output :
Initializing DDR SDRAM...found 4096 MB
Initializing ECC on bank 0
Initializing ECC on bank 1
Initializing ECC on bank 2
Initializing ECC on bank 3
Turning off data cache, using DDR for first time
F
***  Exception ***
Exception vector =
f0
EC
***  Exception ***
Exception vector = 0x00
CPU context of the most recent exception:
PC  = 0x
F
*** ÿÿÿÓÿÿÿÏÿÕ
Î Exception ***
Exception vector = 0x0[0000000000000
PC  = 0x
and i can't enter the rommon so I really appreciate if you help me to solve this issue
Rivalino Tamaela Mon, 01/13/2014 - 14:00
  • Cisco Employee,
Bilal,
Looks to me a hardware issue. Please open TAC case, it most likely end up with RMA.
thanks,
rivalino
bilal Adel Mohammed Tue, 01/14/2014 - 09:26
Hi Rivalino,
Can you explain what  is RMS mean ? and don't you think it is a CRS Bug ?
Rivalino Tamaela Tue, 01/14/2014 - 09:53
  • Cisco Employee,
RMA is replacement of the product that is under warranty or contract. If the RSP is broken due to hardware issue, and if it is under Cisco contract or warranty, you can open the TAC case to investigate this further. If TAC conclude this is hardware issue, then you will receive replacement. I do not think this is a bug, you can open case now and i can work with you to confirm this.
thanks,
rivalino
bilal Adel Mohammed Tue, 01/14/2014 - 10:55
thanks Rivalino for your cooperation
Actually we are beyond the warranty ( unfortunately ), and this RP belong to one of important Core ,and now we have a single point of failur ( only RP1 ).
tomorrow also I will keep trying and if something happened I will ask you again
