01-14-2014 04:40 AM - edited 03-16-2019 09:14 PM
Voice Mail redirecting to a different pilot number or extension.
Guys need help.
I checked with port monitor.
When he presses the messages button, it gets redirected to someother user.
Any changes that has to be made?
Deva.
01-14-2014 04:48 AM
Hi Deva,
Does this same happen when user dial VM pilot number directly ?
I will do a complete DNA to check whether any number translation happening in between or not.
Manish
01-14-2014 04:50 AM
It happens when he presses the messages button as well as the pilot number.
Deva.
01-16-2014 03:26 AM
Check if there is any translation pattern configured.
01-16-2014 04:38 AM
Just to clarify a few things.
You said that you monitored the ingress call using port monitor. Is the calling party number what you expect to see? Meaning, is the calling party number of the call coming into Unity/Unity Connection the number of the user pressing the voicemail button or the other mailbox user?
If the calling party number is presented correctly at Unity/Unity Connection then your issue is how Unity/Unity Connection is configured. I would check Direct call routing rules. I would look at partitions, search space configurations, and alternate extensions. I am assuming that primary extension is accurate.
If the calling party number is presented incorrectly at Unity/Unity Connection then your issue is in the CUCM configuration. I would check:
1. Voicemail profile assigned to the line DN of the phone you are testing. Check the mask assigned to the profile.
2. Check the external mask on the phone line itself.
3. Check all patterns associated with the voicemail pilot number (translation, route pattern, etc.) to see if you are doing any calling party transformations.
Another easy test would be to test from a third user. I assume you have more than two people provisioned in voicemail. Configure (or look at an existing) third user. Make sure this user is using the same VM Profile as the user experiencing the issue. Call voicemail -- does it work correctly? If so, then your issue is on the Directory Number assigned to the affected user's phone. If it does not work then your issue is with the VM profile, translation, route pattern, or some other dial plan component.
-Bill
(b) http://ucguerrilla.com
(t) @ucguerrilla
Please remember to rate helpful responses and identify helpful or correct answers.
