Warning message
ISDN Overlap Receiving Issue
Jan 14th, 2014
I have a H323 Voicegateway working with CUCM 9.1.2.10000-28. Voicegateway is a 3925 Router with Version 15.3(2)T1.
At the moment I have the Problem that some Calls from external fail because the Telco send the digits in overlap at not as en-block as you can see in the following ISDN q931 debug:
Jan 14 13:20:02.158: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x1B0F
Bearer Capability i = 0x9090A3
  Standard = CCITT
  Transfer Capability = 3.1kHz Audio
  Transfer Mode = Circuit
  Transfer Rate = 64 kbit/s
Channel ID i = 0xA98392
  Exclusive, Channel 18
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x2181, 'xxxxxx'
  Plan:ISDN, Type:National
Called Party Number i = 0xC1, '152500'
  Plan:ISDN, Type:Subscriber(local)
Jan 14 13:20:02.158: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x9B0F callID = 0x6D54 switch = primary-net5 interface = User
Jan 14 13:20:02.158: ISDN Se0/0/0:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0x9B0F
Jan 14 13:20:02.258: ISDN Se0/0/0:15 Q931: RX <- INFORMATION pd = 8  callref = 0x1B0F
Called Party Number i = 0xC1, '6'
Jan 14 13:20:02.270: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x9B0F
Jan 14 13:20:02.610: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x9B0F
Cause i = 0x80A2 - No circuit/channel available
Jan 14 13:20:02.662: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x1B0F
Jan 14 13:20:02.662: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x9B0F
Called Number is "152500631" but I receive on the Gateway at first "152500" an then in a scond message the digit "6". The digits "31" are missing.
For testing I've configured ISDN Overlap Receiving on the Serial 0/0/0:15 with 20000 msec, but it still isn't working.
Is there a Timer to fix the problem?
The following is a part of the configuration of the H323-Gateway:
interface Serial0/0/0:15
description *** PMX 1 ***
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-net5
isdn overlap-receiving T302 20000
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
isdn outgoing-voice info-transfer-capability 3.1kHz-audio
no cdp enable
voice-port 0/0/0:15
no vad
playout-delay fax 40
cptone DE
bearer-cap 3100Hz
dial-peer voice 1 pots
description **INCOMING CALLS**
translation-profile incoming PSTN_IN
incoming called-number .T
direct-inward-dial
port 0/0/0:15
Thank you and best regards,
Thomas
Suresh Subramanian Tue, 01/14/2014 - 05:47
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, October 2015
what is your outbound dial-peer to CUCM? did you try configuing the wildcard mask 'T' in the outbound dial-peer to CUCM also?
Please rate all the useful posts
tkauer2591 Tue, 01/14/2014 - 05:49
That's the Dial-Peer to CUCM:
dial-peer voice 30 voip
description 3stellig zum CUCM
preference 1
destination-pattern [1-9]..T
session target ipv4:10.0.0.128
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
Thomas
Suresh Subramanian Tue, 01/14/2014 - 05:58
Instead of 'destination-pattern [1-9]..T' could you please try 'destination-pattern 1T' in a test dial-peer and check?
also from the debug you posted, the call was disconnected with Cause i = 0x80A2 - No circuit/channel available.
Could you please check the ISDN channel status with 'show isdn service' command to ensure all channels are up and idle?
tkauer2591 Tue, 01/14/2014 - 06:07
I've configured the Dial-Peer with the 'destination-pattern 1T' but I have the same problem.
ISDN Channel is up:
ISDN Se0/0/0:15, Channel [1-31]
  Configured Isdn Interface (dsl) 0
   Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
    Channel :  1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1
    State   :  0 0 0 2 0 0 0 0 0 0 0 0 0 0 2 3 0 0 2 2 0 2 0 2 2 2 2 0 2 0 2
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        12 Active Layer 3 Call(s)
        CCB:callid=6D56, sapi=0, ces=0, B-chan=27, calltype=VOICE
        CCB:callid=6D99, sapi=0, ces=0, B-chan=15, calltype=VOICE
        CCB:callid=6D9A, sapi=0, ces=0, B-chan=4, calltype=VOICE
        CCB:callid=E5DD, sapi=0, ces=0, B-chan=20, calltype=VOICE
        CCB:callid=E608, sapi=0, ces=0, B-chan=30, calltype=VOICE
        CCB:callid=E60B, sapi=0, ces=0, B-chan=24, calltype=VOICE
        CCB:callid=E60C, sapi=0, ces=0, B-chan=28, calltype=VOICE
        CCB:callid=E60F, sapi=0, ces=0, B-chan=29, calltype=VOICE
        CCB:callid=E610, sapi=0, ces=0, B-chan=25, calltype=VOICE
        CCB:callid=E611, sapi=0, ces=0, B-chan=23, calltype=VOICE
        CCB:callid=E612, sapi=0, ces=0, B-chan=21, calltype=VOICE
        CCB:callid=E613, sapi=0, ces=0, B-chan=26, calltype=VOICE
    Active dsl 0 CCBs = 12
    The Free Channel Mask:  0xC0273FF7
    Number of L2 Discards = 0, L2 Session ID = 3
Suresh Subramanian Tue, 01/14/2014 - 06:20
when you configure "destination-pattern 1T" what is the disconnect cause code you get? same 0x80A2?
could you please post debug isdn q931 again with 1T config?
tkauer2591 Tue, 01/14/2014 - 06:32
Same Error:
Jan 14 14:25:58.975: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x1BB8
  Standard = CCITT
Channel ID i = 0xA98387
  Exclusive, Channel 7
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '83039239214'
Jan 14 14:25:58.975: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x9BB8 callID = 0x6DFC switch = primary-net5 interface = User
Jan 14 14:25:58.975: ISDN Se0/0/0:15 Q931: TX -> SETUP_ACK pd = 8  callref = 0x9BB8
Jan 14 14:25:59.075: ISDN Se0/0/0:15 Q931: RX <- INFORMATION pd = 8  callref = 0x1BB8
Called Party Number i = 0xC1, '3'
Jan 14 14:25:59.087: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x9BB8
Jan 14 14:25:59.411: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x9BB8
Jan 14 14:25:59.471: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x1BB8
Jan 14 14:25:59.471: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x9BB8
acampbell Tue, 01/14/2014 - 06:48
  • Green, 3000 points or more
Thomas,
I think your issue is either on on the link or the ISDN service.
If the problem was the didit signalling you would more likely send a cause
Cause i = 0x8081 - Unallocated/unassigned number
You are sending
Alex.
Please rate useful posts.
Ayodeji Okanlawon Tue, 01/14/2014 - 06:53
  • Cisco Designated VIP,
    2017 IP Telephony
Alex is spot on here...Your gateway is sending a disconnect of
You need to investigate that before anything else...
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
tkauer2591 Tue, 01/14/2014 - 07:23
I have the Error "Cause i = 0x80A2 - No circuit/channel available" only when I receive a call like I've described above. All other calls are working without any errors
Ayodeji Okanlawon Tue, 01/14/2014 - 07:29
    2017 IP Telephony
Nest step will be to take your logs and contact your provider.Ask them why they are sending overlap digits...Find out the reason for this anomaly..Since the rest of your calls are sent enbloc..Show them your logs..
tkauer2591 Tue, 01/14/2014 - 07:41
I've already talked to the provider. The told me that they can't change anything in their configuration. When a call is established from an analog phone from external it's sending overlap digits. When the call is established from an ISDN or VoIP Phone it's sending enbloc...
tkauer2591 Thu, 01/23/2014 - 04:33
I've opened a TAC-Case for this issue. I will update this discussion if I have any solutions.
MOHIT SINGH Thu, 01/23/2014 - 06:18
  • Bronze, 100 points or more
Hi Thomas,
In case of overlap receiving PRI you should not configure "direct-inward-dial" in inbound POTS dial peer. If direct-inward-dial is configured then gateway will try to route the call as soon as ISDN setup is received and it will not wait for remaining digits due to which call will fail with "unallocated/unassigned number". To fix the issue you should remove direct inward dial from dial peer
no direct-inward-dial
Below is good doc wich explains the overlap behaviour in detail
https://supportforums.cisco.com/docs/DOC-25562
Mohit Singh
Related Content
