Warning message
Android 4.3 VPN to ASA running 8.4.4(1)
Jan 14th, 2014
                   Ok guys need some help.  Took me a little time to get it to pass phase 2 but it still won't connect.
This is the output of the debug just after completing phase 2
Jan 14 17:30:26 [IKEv1 DEBUG]Group = VPN_L2TP, IP = 108.38.203.107, Starting P2 rekey timer: 24480 seconds.
Jan 14 17:30:26 [IKEv1]Group = VPN_L2TP, IP = 108.38.203.107, PHASE 2 COMPLETED (msgid=af981d0d)
Jan 14 17:30:26 [IKEv1]IKEQM_Active() Add L2TP classification rules: ip <108.38.203.107> mask <0xFFFFFFFF> port <4500>
Jan 14 17:30:28 [IKEv1 DEBUG]Group = VPN_L2TP, IP = 108.38.203.107, IKE SA AM:0c773824 rcv'd Terminate: state AM_ACTIVE  flags 0x00000041, refcnt 1, tuncnt 1
Jan 14 17:30:28 [IKEv1 DEBUG]Group = VPN_L2TP, IP = 108.38.203.107, sending delete/delete with reason message
Jan 14 17:30:28 [IKEv1 DEBUG]Group = VPN_L2TP, IP = 108.38.203.107, constructing blank hash payload
Jan 14 17:30:28 [IKEv1 DEBUG]Group = VPN_L2TP, IP = 108.38.203.107, constructing IPSec delete payload
Jan 14 17:30:28 [IKEv1 DEBUG]Group = VPN_L2TP, IP = 108.38.203.107, constructing qm hash payload
Jan 14 17:30:28 [IKEv1]IP = 108.38.203.107, IKE_DECODE SENDING Message (msgid=ed44a762) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 68
Jan 14 17:30:28 [IKEv1 DEBUG]Group = VPN_L2TP, IP = 108.38.203.107, Active unit receives a delete event for remote peer 108.38.203.107.
Jan 14 17:30:28 [IKEv1 DEBUG]Group = VPN_L2TP, IP = 108.38.203.107, IKE Deleting SA: Remote Proxy 108.38.203.107, Local Proxy 23.25.183.161
Jan 14 17:30:28 [IKEv1 DEBUG]Group = VPN_L2TP, IP = 108.38.203.107, IKE SA AM:0c773824 terminating:  flags 0x01000001, refcnt 0, tuncnt 0
Jan 14 17:30:28 [IKEv1 DEBUG]Group = VPN_L2TP, IP = 108.38.203.107, constructing IKE delete payload
Jan 14 17:30:28 [IKEv1]IP = 108.38.203.107, IKE_DECODE SENDING Message (msgid=ddeff6f) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 80
Jan 14 17:30:28 [IKEv1 DEBUG]Pitcher: received key delete msg, spi 0x42fc488c
Jan 14 17:30:28 [IKEv1]Group = VPN_L2TP, IP = 108.38.203.107, Session is being torn down. Reason: L2TP initiated
Jan 14 17:30:28 [IKEv1]Ignoring msg to mark SA with dsID 65536 dead because SA deleted
This is the running config
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA mode transport
crypto dynamic-map dyn1 1 set ikev1 transform-set ESP-AES-256-SHA ESP-3DES-SHA
crypto dynamic-map dyn1 1 set reverse-route
crypto map outside_map 100 ipsec-isakmp dynamic dyn1
crypto map outside_map interface outside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
tunnel-group VPN_L2TP type remote-access
tunnel-group VPN_L2TP general-attributes
address-pool VPN-Pool
default-group-policy l2tp-ipsec_policy
tunnel-group VPN_L2TP ipsec-attributes
ikev1 pre-shared-key *****
tunnel-group VPN_L2TP ppp-attributes
authentication ms-chap-v2
group-policy l2tp-ipsec_policy internal
group-policy l2tp-ipsec_policy attributes
dns-server value 172.16.10.10 172.16.10.9
vpn-tunnel-protocol l2tp-ipsec
default-domain value crwdb.int
address-pools value VPN-Pool
The Android device is configured to land on the VPN_L2TP Tunnel Group.
Thanks in advance.
