Warning message
routing on P2P connection
Jan 14th, 2014
Hi All
I have P2P connection with serial interface
Router A IP address 172.16.1.65. 255.255.255.252
Router B IP address  172.16.1.66 255.255.255.252
when I check routing table wih sjh ip route on router A
its show Router B IP address as directlu connected
C       172.16.1.64/30 is directly connected, Serial0/3
C       172.16.1.66/32 is directly connected, Serial0/3   Router B IP address.
interface Serial0/3
bandwidth 2048
ip address 172.16.1.65 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
ip route-cache flow
end
and when I traceroue to 172.16.1.65 first hop is 172.16.1.66.
How to rectify
Please help.
cadet alain Tue, 01/14/2014 - 23:46
  • Purple, 4500 points or more
PPP advertises the IP address of the peer as a directly connected  /32  due to peer neighbour-route feature that enables peers to have IPs on different subnets.
So if you want to get rid of this /32 you must enter this in interface config:
no peer neighbour-route (on each side)
or change encapsulation to hdlc with the interface config command no encapsulation ppp
Concerning the communication with your own IP on a serial link( whether it is ppp or hdlc) ,what you observe is normal and can't be changed.When communicating with your IP the packet is sent on the link, goes to peer which sends it back to you.
Alain
