Warning message
Jouni Forss Wed, 01/15/2014 - 04:32
If you are asking that can the VPN devices public IP address be used as the source IP address for traffic in the actual L2L VPN connection then the answer is yes.
Even though we usually dont do this we still have such setups in on some customers.
Hope this helps
- Jouni
Jeferson Palma Wed, 01/15/2014 - 04:48
The scenario is that in one side I have a ASA firewall, where I don´t need to use the same ip to close the IPSec and originate the traffic. But we are closing the VPN with a Linux server directly, where it has only one IP, a public IP. So, in this Linux server I need to use this unique IP to establish the IPSec VPN and to originate the traffic of the application. I need to know if it is possible.
Jouni Forss Wed, 01/15/2014 - 05:18
If this was a question regarding the ASA having the single public IP address for both peer IP and source in Encryption Domain then I could say it would work.
I would expect it to work with the Linux server also but I can't say for sure and I am not sure if anyone else can say either unless they have used such setup.
Might get an answer easier on some discussion more focused on Linux.
- Jouni
colinlim.au Mon, 09/01/2014 - 17:06
I can confirm that it works.  We have configured a standalone Linux server with openswan connecting with the ASA in a Site-to-Site VPN configuration.
Colin
purva.kate Tue, 09/02/2014 - 19:41
For Site-to-Site VPN.
Can you tell me,if we can use the Public IP address (Outside interface ip address on which Tunnel is terminating) in the Encryptino Domain as Source ?
swapnildongre89 Wed, 06/17/2015 - 01:10
I have the same question which Purva.Kate has. Can anyone please confirm if it works or not?
