Warning message
Encryption provided to VPN Client
Answered Question
Jan 15th, 2014
                   Hi Everyone,
Need to confirm if user PC used Cisco RA  VPN to connect to corp Network.
Here IPSEC tunnel which is build between User PC and VPN gateway the encryption is provided by VPN Client software to user data right?
Mahesh
Correct Answer by Marvin Rhoads about 3 years 7 months ago
Mahesh,
IPSec would protect the data in transit to networks reached via the head end via the VPN. It does nothing to data at rest (stored) on the client.
Remote Access VPN clients negotiate the encryption based on the settings in the head end ASA (or whatever device terminates the corporate remote access VPN). It can be SSL or IPSec method with other various parameters according to configuration settings.
Once a VPN session is established, the client software encapsulates traffic going to the head end and decapsulates data received using the negotiated settings. The head end does the same.
Overall Rating: 5 (2 ratings)
Correct Answer
Marvin Rhoads Wed, 01/15/2014 - 20:21
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
mahesh18 Wed, 01/15/2014 - 20:34
Hi MArvin,
I check the VPN client software on the user PC under transport it has IPSEc over TCP so does it mean that IPSEC provides the encryption to the Client Data?
Mahesh
Correct Answer
Marvin Rhoads Wed, 01/15/2014 - 20:50
  • Hall of Fame,
Mahesh,
